Do i need to change a/t fluid filter or just change fluid?
Old Oct 28, 2004 | 06:21 PM
Whtmax'01's Avatar
I checked my transmission fluid and its has this light red brownish color, not pure red like it is when its new. Do i need to replace the filter with te fluid or just the fluid will be enough?
Old Oct 28, 2004 | 06:59 PM
SoonerFan's Avatar
Cletus
you can change the filter but you dont have too. i have 88K miles and havent changed it. i plan on doing it one of these days. you have to drop the pan to get to it and there are about 20 little bolts
Old Mar 25, 2005 | 05:08 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if you drop the pan, just check the screen for damage. while it acts like a filter, you should not need to replace it unless you find tears. i just wiped mine down to remove any buildup on the mesh.
Old Mar 25, 2005 | 05:43 AM
makavelisk's Avatar
On my old max I had the fluid and filter changed at 95k miles and I wasnt having any problems.
Old Mar 25, 2005 | 06:13 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
It is not a filter it is just a screen.... you don't need to replace it....just clean it with a good brake cleaner and re install it. See my sig for more info.....
Mar 12, 2020 12:06 AM
iamute
Sep 20, 2015 05:22 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxxx10
Sep 13, 2015 03:16 PM
sdotcarter
Sep 2, 2015 09:53 PM
