Transmission Service Deal Question
Old Oct 29, 2004 | 02:41 PM
S00NR1's Avatar
OU > *
Just got a coupon in the mail today from one of the tranny specialists just down the street. For $34.97 I would get:
-Road Test
-Band & Linkage Adjustment
-Check for Leaks
-New fluid and clean filter
-Replace pan gasket
(Reg $70.00)
Does this sound like a good deal? And does their "replace pan gasket" terminology basically just sound like dropping the pan and cleaning it out? I am going to call them to see if they will accept my own fluid for the change as well. Thanks.
Old Oct 29, 2004 | 03:34 PM
jzwu's Avatar
Dealer charges about same for tranny fluid change with Nissan fluid.
Old Oct 29, 2004 | 04:52 PM
Rogo02SE's Avatar
For full flush it's a great deal. If it's only drain and fill I wouldn't bother with it.
Old Oct 30, 2004 | 08:13 AM
S00NR1's Avatar
OU > *
Okay, so apparently they would drop and clean the pan with that deal, so I guess I will buy some Mobil 1 ATF and have them use it for the flush.
Old Oct 30, 2004 | 08:29 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Its a drop the pan change gasket, probably don't bother cleaning it up- kinda deal. And as far as them putting your own ATF in.... I would like to watch them do it. Since Maximas have a bolt on the bottom of the tranny pan, I seen some shops "service" the tranny by just draining the tranny from there. Then filling up the tranny via dip stick hole. I would just flush the tranny, chances are the "new" tranny gasket they will install is going to leak.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
