tranny cooler installed
Old Apr 15, 2001 | 05:28 PM
kafene's Avatar
took about 3.5 - 4 hours of beer, uh, i mean, work
the install is easy (although it would have taken me forever w/o my friend)
the tranny cooler i got was the hayden 478 (the largest i could find). it cost me $80 (heavy duty model costed me more than the aluminum). i didn't have time to get redline, so i got mobil 1 synthetic (from pepboys for $5.99 each) car took in 4 quarts.
tranny cooler kit has all the things you need and is really easy to install (AFTER THE FRONT BUMER WAS REMOVED). my friend wanted easy access and work area, so he wanted the front bumper to come off. (btw, it may take longer w/ hand tools; this was done w/ air tools)
one of these days, i'll have to take pictures of an install so i can post it. sorry, no pics of the install.
Old Apr 15, 2001 | 05:33 PM
LoveSick's Avatar
Beer and work.?? Same thing!!!
BTW, do you need drilling and cutting when installing the cooler? How did you managed to drain all the oil?
Old Apr 15, 2001 | 05:48 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
No cutting besides the new hoses and plastic thingies), drilling, or draining necessary.
Old Apr 15, 2001 | 06:11 PM
mdeal's Avatar
Why did you go with a larger cooler?
Old Apr 15, 2001 | 06:22 PM
Y2KevSE's Avatar
To keep his beer yummy.
Old Apr 15, 2001 | 06:36 PM
kafene's Avatar
i went w/ the largest cooler because...
i read a post that said to get the biggest one you can get. the size doesn't seem to big to me, these coolers are pretty small imo, although mine's rated for larger trucks that tow. the stock cooler shares the cooler w/ the radiator, which means it's not really being cooled since the radiators always hot just from the coolant.
there was no drilling, and the hosing was placed under the car to the stock tubing. there was enough tubing (and a little extra) because we used some of the stock tubing where there is a sharp bend to fit back into the tranny. we did this to avoid any sharp bends in the tubing because robert said the heat would make the tubing more pliable and didn't want it getting 'pinched' because it got 'soft', stealing valuable fluid from the tranny.
actually, there was almost NO oil from taking out the tubing (maybe a couple of table spoons). i drained the transmission fuild from the drain pipe located under the pan, just like doing an oil change.
kafene.
Old Apr 16, 2001 | 12:46 AM
Menasor's Avatar
I am thinking of getting one this summer, the only dilemma that i have is where to install it. Any one have any pics of this kind of install. Is there a how-to tread or site on installing a transmission cooler?
Old Apr 16, 2001 | 06:13 AM
psing23's Avatar
is there anyone in NYC/Northern Jersey/Long Island area that knows how to install one and is willing to help me install mine?
lemme know cause i am interested in this as well.
btw kafene where did you buy the cooler from?
thanks
-danny
Old Apr 16, 2001 | 07:14 AM
jwletourneau
It sounds like this was a pretty tough job. My brother installed a trans cooler in a Dodge 1/2 ton so that it wouldn't overheat while pulling his boat. Though it only took a couple of hours...
Old Apr 16, 2001 | 08:05 AM
psing23's Avatar
jwletourneau... where did u choose that name from? do you have any affiliation with tourneau the watch store?
Old Apr 16, 2001 | 02:33 PM
Lumbee799's Avatar
What kind of performance difference will this offer or what kind of effects do you expect from this addition?
Old Apr 16, 2001 | 06:47 PM
mdeal's Avatar
There is no performance benefit. It is designed to keep your transmission more healthy from more frequent shifts or trailing towing. Lessens wear-and-tear.
Old Apr 16, 2001 | 07:21 PM
brubenstein's Avatar
A transmission cooler keeps the transmission fluid from getting too hot, which is what kills a transmission. Anytime the fluid temperature goes above 240 degrees the fluid begins to break down and the transmission sustains damage. It may not be detectable in the beginning, but the effects are cumulative.
The biggest possible cooler that you can fit, is probably not the best cooler. If the fluid doesn't reach a certain temperature (there is a sensor in the transmission), it will not shift into OD. All you need is a small cooler to keep the temp in the right range (unless you are road racing - on a track). Synthetic ATF is also a big help.
A properly sized cooler and frequent (30k miles) fluid changes, with synthetic ATF, can double the life of a transmission; if you start by doing this from day one.
Old Apr 17, 2001 | 11:05 AM
kafene's Avatar
i got it from pepboys.
thanks
-danny
they have several sizes at different prices. i dindn't get the aluminum because it looked a lot more fragile.
kafene.
Old Apr 17, 2001 | 04:36 PM
jwletourneau
I wasn't very creative when I setup my account and used my name. No, as far as I know I have no affiliation with a watch company. If I could go back a edit my account name I would. How does GXEme sound :-).
Old Apr 17, 2001 | 06:19 PM
GXEme's Avatar
Ok, I'm now GEXme instead of jwletourneau. One of the many benefits of having a million email addresses!
MaxLife17
Jun 27, 2019 01:37 PM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
