Mass Airflow sensor..Help!!!
Old Nov 3, 2004 | 08:23 PM
bigpants's Avatar
I've been told that my mass air flow sensor requires replacement...the dealer wants $286, I noticed a air mass meter available on-line for about $110. Is it the same part (just a different name)?...Is it hard to replace?
Sorry..it's a 2000 max se
Thanks!
Old Nov 3, 2004 | 08:30 PM
Puppetmaster's Avatar
What year is your Max? Either way, check out this thread... it may answer some of your questions.... http://forums.maxima.org/showthread.php?t=348395
Old Nov 3, 2004 | 09:02 PM
vortechpower's Avatar
No it is not hard to replace. It is right there on your intake!
Old Nov 3, 2004 | 09:22 PM
But if he has an 02 or 03... he either has to get a $400 AM-600 MAF replacement, or he can go with a $90 2k1 MAF, but will have to transfer the IAT sensor from the existing MAF... (I learned all that from the thread I posted above )
Old Nov 4, 2004 | 06:30 AM
tankyard
The part # for the MAF sensor for the 2000 Max is 226802Y001 and it usually retails for about $90.00-$100.00. Be sure to ask for that specific part # because they may try to sell you older stock which retails for about $400.00. You will also have to have your ECU re-programmed by a dealer after the replacement. I own a 2000 max myself and had the opportunity to do the research over several months before I changed mine.
Old Nov 4, 2004 | 06:57 PM
bigpants's Avatar
MAF Sensor
OK..I found the part for about $80..good deal but what about reprograming the computer?...what's the deal with that?...can I pull the battery cable?...would that clear the error code from the memory? sorry...i don't have experience in this area.
TallTom
57
Oct 14, 2025 05:16 PM
iflexsteel
Sep 15, 2015 03:37 AM
cash94
Aug 27, 2015 08:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
