WTF is up with my rotors/pads?
Old Nov 3, 2004 | 09:33 PM
XGaSpAcHo
I had new brake pads put on as well as had my rotors machined about 5,000 miles ago because the front of the car would tremble everytime I tried to slow down or stop. That fixed the problem, until now. It's not nearly as bad as it used to be but it's starting to come back again. Is there something wrong with my rotors/pads or is this normal? And is there anything I can do to prevent it from happening again or so quickly after just having my brakes done?
Old Nov 3, 2004 | 09:48 PM
Rich96's Avatar
Unless they are overtorqued, its just classic Maxima rotors. I drive like an SOB and had the same problem after about 5 - 10K AFTER I had them turned.
I switched to Brembo blanks and it got a little better - but they still give me problems. Next time I'll try X drilled but I doubt it will do much.
Old Nov 4, 2004 | 06:10 AM
XGaSpAcHo
cross drilled rotors don't warp as badly i take it. and what are bremos? rotors or pads?
Old Nov 4, 2004 | 06:56 AM
desperado_45's Avatar
The problem can be all but solved with "frozenrotors"
But they are costly at 105.00 per rotor
Old Nov 4, 2004 | 06:57 AM
KCMC582's Avatar
the brembos he means are rotors, brembo blanks are just not x drilled/slotted. i have the same vibration, and it sucks. my pads are good, rotors are shot. i dont wanan replace them until i need to, and ill get some NICE rotors. pick up some irotors or powerslot or something like that, even brembo blanks.
Old Nov 4, 2004 | 07:12 AM
bigdeez4u's Avatar
Sorry guys i'm new here. I've heard this is just how Maximas are bc of there wight and to small of rotors. i've got about 70,000 on mine and trust me there getting BAD. I've heard everyone say go to the X drilled. Any ideas on what is the best bang for the buck? What i mean is where is a good place to get them and what brand.
Old Nov 4, 2004 | 07:20 AM
wild willy's Avatar
Bottom line Nissan rotors suck.......Once turned....expect less miles til they need turned again. Mine warped 3 X in 11K miles
Old Nov 4, 2004 | 07:21 AM
MaxMaMaSE's Avatar
Actually... Rotors normally warp because the brakes were not "bedded" properly when new. Then the internal properties of the metal are incorrect and once the rotor warps eventually it will return to being warped even if it is turned by the shop.
Take a look at this:
http://www.stoptech.com/whitepapers/bedincontents.htm
Old Nov 4, 2004 | 07:42 AM
XGaSpAcHo
so here's the question before me right now. when my rotors get really warped to a point where i can't stand the vibration anymore. do i spend the $200 on getting new nissan pads and the rotors machined or do i go with one of the other options you guys suggested? which one makes more sense moneywise?
and can anyone suggest a place to get the bremo pads/rotors? just so i can get an idea of how much this is going to cost me. thanks.
Old Nov 4, 2004 | 07:49 AM
MaxMaMaSE's Avatar
Get new Brembo's
Check Ebay, always good price's for new rotors and pads on there.
Old Nov 4, 2004 | 08:03 AM
XGaSpAcHo
brembos for rotors, pads or both? slotted/cross drilled or regular? and is there a specific size? sorry to be such a newb.
Old Nov 4, 2004 | 08:38 AM
tothamax01's Avatar
ebay has a set of brembo rotors that im looking at for my max i think they are about $230 for front and back. thats the best deal i have found on them. heres a the web site
http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
-adam
Old Nov 4, 2004 | 09:04 AM
XGaSpAcHo
Thanks a lot man! I'll have to look for something similar when mine get worse. I'd like to get atleast 3K more miles out of these before swapping them. Atleast now I know what a good price is now. What about pads? What kind should I get and where?
Old Nov 4, 2004 | 09:07 AM
SkoorbMax's Avatar
I'd avoid buying stock rotors.
I had my 2000's rotors turned 9k ago and they're still good. Generally the turned rotors won't last as long as new ones, but our rotors are quite expensive, and turning them only costs $15, which is why I did it...plus half the people said don't bother ("they'll warp right away again), and half said turning is a good idea.
Old Nov 4, 2004 | 09:15 AM
XGaSpAcHo
so don't get the brembo rotors? just turn the stock ones to get more life out of them?
Old Nov 4, 2004 | 09:27 AM
stevieb77's Avatar
-adam
I just went through all of this 3 weeks ago, I have a 2003 and @ 28K the rotors and pads where shot. Brembo doest offer Rotor's for the 03 yet. Some places say they have them but there not for the 03. I ended up just getting a pair of OEM Rotors and some ceramic pads. Dont turn the rotors, the stock ones are paper thin. Good luck
Old Nov 4, 2004 | 09:30 AM
XGaSpAcHo
Thanks stevie. Where did you get your pads?
Old Nov 4, 2004 | 10:59 AM
TrexMax001's Avatar
Brembo slotted/cross-drilled with Wagner Quiet-Cool ceramic pads.
Wonderful !!
Trex
Old Nov 4, 2004 | 11:07 AM
XGaSpAcHo
those look pretty sweet. where did you get those and how much did they cost if you don't mind me asking?
Old Nov 4, 2004 | 12:46 PM
TrexMax001's Avatar
http://forums.maxima.org/showthread.php?t=349023
Old Nov 4, 2004 | 01:06 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
Brembo blanks are the best from my understanding, slotted are good as well(that what i have) and cross drilled are ok. The argument from powerslot is that cross drilled my crack more easily, but i dunno if that is 100% true. so i ended up going with power slot brembo rotors purchased in a GD the .org. i think it is still up, or goes on forever or somethin like that.
Brembo powerslot and pbr ceramic pads.
not a close up, but you get the idea.
Old Nov 4, 2004 | 03:23 PM
XGaSpAcHo
is this it? http://forums.maxima.org/showthread.php?t=350834
nice rims by the way
i kinda wanted slotted/cross drilled like trexmax but it looks like those aren't available through this GD.
Old Nov 4, 2004 | 05:12 PM
Maxima112's Avatar
no that isnt it....the person selling them was from California. and it totaled me about 300 with pads....i not sure if he is still on the org, his car got smashed and he got an old school M5.... id have to look around for him if you want to buy from him.
Old Nov 4, 2004 | 05:17 PM
XGaSpAcHo
i appreciate it but don't bother. i'm gonna try to see what life i can squeeze out of the current rotors because they're not warped too badly yet. when i'm serious about buying i'll have to look you up or try to find a good deal on these somewhere. i just wanted to do the research now so that when i finaly do want to change my rotors i'll be educated in the matter and know what to get. thanks again man i really appreciate it.
Old Nov 4, 2004 | 05:58 PM
NJ Devils Fan's Avatar
My rotors are warped and they are progressively getting worse. I am going to switch to slotted/cross drilled brembo soon, probably hold off until after christmas and get eibach springs and illumina shocks/struts and have everything put on at the same time.
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
