Front Left Bose Speaker just stopped!!
Old Nov 4, 2004 | 11:38 AM
silversurfersg's Avatar
Hi. My Front left Bose speaker stopped working a day ago. Sound crackles sometimes and im not sure it the tweater is working either. If i change the Fader and Balance around everything else works fine. Any suggestions? Loose wire?
And yes I did also post this in the audio session, but its not as busy there.
I need my music back asap.
Old Nov 4, 2004 | 11:42 AM
Doug Simpson's Avatar
Typical problem. I bought a 2002 5 weeks ago and the left side stops while playing cd's. Got sick of it and got an aftermarket system since it was out of warranty. If you look further on here you will see it is a common problem. What yr Max is yours?
Old Nov 4, 2004 | 11:54 AM
MaxPayne2002's Avatar
I have the same problem I know its pretty common with the Bose.
I believe its the HeadUnit (I think) Theres been quite a few posts about
it in the past.
Old Nov 4, 2004 | 11:58 AM
TXT-1's Avatar
There is a TSB on this. But I think it only covers 02-03 with certain vin #s
Old Nov 4, 2004 | 12:00 PM
Puppetmaster's Avatar
Yup... this is a common issue with the 2k2s... replaced one HU already... some other people have had 4-5 HUs replaced... the Bose is just a PITA... get an aftermarket...
Btw, the Audio forums might have more threads on this... check that out too...
Old Nov 4, 2004 | 03:08 PM
nyautostyle's Avatar
go with aftermarket speakers and not have to deal with this issue once again.. I changed my speakers once with planetaudio speakers which i sell and i havent had a problem with them. There are a lot of speakers to choose from out there, get some feedback in the forums if u decide to change em... good luck
Old Nov 4, 2004 | 07:34 PM
LSUmax's Avatar
nyautostyle
are u saying that if u change the stock bose speakers this problem should go away? I am getting ready to get my second head unit next week.
Old Nov 4, 2004 | 09:02 PM
Irl4512's Avatar
I had the same problem with my rear speakers (both of them, but not sub) and after 3 new head units and a new amp from Nissan, found out it was none of the above. Took it to an acutal audio repair shop and found out that it was just a loose speaker wire clamp...so if you can find those in the car, check them over. Snapped mine back together and now both speakers are working properly again. Here are some pics of the clamps i am talking about...this just happens to be the one for the rear speakers.
Old Nov 4, 2004 | 09:50 PM
Yeah, I was thinking it was more to do with the speaker connection and not the HU... just haven't had time to check it out.... thanks for the info....
Old Nov 6, 2004 | 02:09 PM
i was thinking it was more of a connection problem, since it happened its come on once or twice. For those who were asking a have a 2001 not 2002
Old Nov 6, 2004 | 05:20 PM
MaximaDudes's Avatar
hey Irl4512 where were those speaker clips? i cant seem to place where your pictures are and im guessing the clips for the front speakers are in the doors?
thanks
Old Nov 6, 2004 | 07:53 PM
Irl4512's Avatar
Those clips are in the trunk, right behind the drivers side rear seat, so right above the pass-through into the trunk. Those are the 2 for the rear speakers. The front ones I am not too sure of, but someone has to know from experience where the front ones would be.
Old Nov 7, 2004 | 09:40 PM
Teufelhunden's Avatar
i have a 2k3, ive seen the tsb about the HU, its funny cuz when i hit a bump the speaker goes out, and then when i hit another bump the speaker is back, i dont know
if i should take it to the dealers or just buy a new HU, this is covered by warrenty right?
Old Nov 8, 2004 | 05:54 AM
TXT-1's Avatar
If it's the speaker connection, why is it only my CD player cuts out and everything else works fine?
Old Nov 8, 2004 | 06:36 AM
Oh right, sorry.... thanks for the reminder.... that's what I found too... just forgot about that since I never really listen to anything other than cds.... haha... my bad.... in fact, I even posted what you just said somewhere else... so yeah, its just the cd player that cuts in and out... and therefore, its unlikely that its the connection...
Another I just realized this past week is it happens when I brake hard too.... the sound either comes back in or cut outs when I have to brake hard to stop.... although, not everytime, but more often than not...
Old Nov 8, 2004 | 10:07 AM
maybe ill try to look for some connectors in the front
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
MikesChevelle
Aug 9, 2015 11:50 AM
rhonster
Aug 6, 2015 05:46 PM
