Anyone with 20mm spacers/ Stock wheels and Lowered?
Old Nov 5, 2004 | 02:34 PM
Fezzik's Avatar
I was wondering if anyone has 20mm spacers in the rear of stock wheels and have been lowered by springs and struts or coilovers. the reason I ask is cause i am getting some coilovers and i have 20mm spacers in the rear. Has anyone done this yet? If so did you have to roll the fender lip that goes in the wheel well? Or did everything clear?
Old Nov 5, 2004 | 02:37 PM
Jeff92se's Avatar
I'm needing a caw
That's over 3/4" of spacer. I hope you plan to run some longer studs if you want to do that.
Old Nov 5, 2004 | 04:50 PM
Fezzik's Avatar
The spacer are fine. The studs came with the H&R spacers.
Old Nov 6, 2004 | 08:40 PM
Fezzik's Avatar
Anyone????
Old Nov 6, 2004 | 09:53 PM
Jeff92se's Avatar
I'm needing a caw
How is anyone supposed to know if the wheels/tires will rub if you don't mention what wheels/tires you are using???
Old Nov 6, 2004 | 11:58 PM
sooner02r1's Avatar
He said he had stock wheels.
Old Nov 8, 2004 | 09:24 PM
Fezzik's Avatar
LOL geez no one huh. Well i guess i'll be the test subject. i am trying to figure out if i need to bend the lip that sticks in on the fender on the rear wheel wells.
Old Nov 8, 2004 | 09:28 PM
Ammi's Avatar
350 Detroit Muscle
It seems like you will be fine using 20mm spacers
Old Nov 9, 2004 | 05:38 AM
WildmanAL's Avatar
Damn H&R, I wish these freakin things would come off backorder.
Old Nov 9, 2004 | 06:03 AM
ZIPPIN's Avatar
Mauja He Mauja
looks like they have em in stock...
http://store.yahoo.com/import-store/4065662a.html
Old Nov 9, 2004 | 02:50 PM
WildmanAL's Avatar
Nope they're still out of stock.
Old Nov 18, 2004 | 06:26 AM
jay23's Avatar
Re: Wheel spacer
well if i where u i would just call or check the website www.wheelspacers.com
Old Nov 18, 2004 | 07:00 AM
chris'smax's Avatar
I've got them in the rear with my 19's and i am dropped around 3.5" in the back and had minor rubbing so i think you should be fine
Old Nov 18, 2004 | 07:25 AM
Fezzik's Avatar
Well I dropped the car an inch in the rear with the stock tires. Not even close to rubbing. So thanks guys.
Old Nov 18, 2004 | 09:28 AM
WildmanAL's Avatar
Do you have these spacers? I just called and they said $65 each for 10mm spacers with the hubcentric rings that will fit my wheels or just $40 each without the hubcentric ring. Even with 10mm I'm still able to get my hubcentric rings that I have now over the hub so I wouldn't think I would need to pay the extra $50 for them to put a ring on them for me. The guy said it would vibrate like hell if I didn't have them.
Old Nov 18, 2004 | 02:05 PM
Fezzik's Avatar
no matter what. You have tgo have the hubcentric ring on there. Its unsafe to not have it.
Old Nov 18, 2004 | 03:31 PM
Galo's Avatar
Maxima Pilot
My first version/try at spacers for the rear were indeed 20mm H&Rs on wheels with nearly the same offset as the OEM 17 inchers and they fit fine, meaning, no rubbing or anything like that.
I replaced the 20mm spacers with 12mm custom-made spacers as I found the 20mm to be just too much.....if I had to pick H&R spacers I would go with the 15mm spacers, not the 20mm ones....
Here's a couple picks of what 12mm spacers look like....
http://www.cardomain.com/id/elgalo
Old Nov 18, 2004 | 08:34 PM
WildmanAL's Avatar
By getting a flat spacer and just using the hubcentric ring I already have should be fine. The spacers are hubcentric and the ring I'm adding will make it wheel centric.
Old Nov 19, 2004 | 12:06 PM
Fezzik's Avatar
That I dont know. I have never tried this or heard if its safe. So new one on me. Sorry if I was sounding overbearing
vingodine
45
May 21, 2016 12:46 PM
tcb_02_max
Sep 11, 2015 12:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Justin Kroll
Sep 2, 2015 11:06 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
