Pathfinder Throttle Body?
Old Nov 12, 2004 | 06:07 AM
chris'smax's Avatar
Can the pathfinder throttle body be used on a 2000?
Old Nov 12, 2004 | 09:25 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Not the older one 4th gens are using, since ours has the IAV(Idle Air Valve) built in.
I've wondered if the 2001 VQ35 Pathfinder TB would work or one from another Nissan vehicle. It's worth a look, but the IAV is the catch. It has to have something similar for the ECU to work.
Are you Fed or Cali spec?
Old Nov 12, 2004 | 09:54 AM
chris'smax's Avatar
I'm fed spec.
Old Nov 12, 2004 | 05:41 PM
midnightmax01's Avatar
i thought that the pathfinders had a cable throttle and not an electronic one pleas correct me if im wrong
Old Nov 12, 2004 | 06:53 PM
I30swimmer's Avatar
doesnt matter 2000-2001 uses cable throttle.. not electronic.. i really dont see the advantage of having electronic throttle anyways.... more compnents to break and it weighs more over all.. WTF
Old Nov 12, 2004 | 06:56 PM
JClaw's Avatar
Get a Q45 TB like Tilley instead
Old Nov 13, 2004 | 06:48 PM
yeah i know isnt that retarded, even the new sentras use an electronic throttle
Old Nov 13, 2004 | 08:00 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Q45 TB is not needed on a such low HP car like Tileys even. Its over kill and it will not work. Q45 TB is good when making over 350HP, not 200.
Old Nov 19, 2004 | 02:14 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
Maybe you should research before speaking, Its on my BOOSTED max
Old Nov 19, 2004 | 03:28 PM
IceY2K1's Avatar
eGas makes sense....it's a simple solution to the On/Off throttle sensitivity problem us VQ30s have. Instead of a direct connection to the throttle-plate they can't control via enough bypass air, they can program in whatever change rate/delay they want to "smooth" out throttle transitions so it's not so jerky.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
