SES light Pulled P0174 code
Old Nov 14, 2004 | 07:51 AM
rdking's Avatar
My SES light has been on and off twice in the past 2 weeks went to autozone today pulled 0174 code system too lean bank 2 code. I'm not sure what to check or replace for this code. I'm guessing either the maf meter or o2 sensor but would'nt an o2 sensor problem throw a specific code for that sensor? Car is a 2000 with 61,000 miles any ideas out there? I hate getting ripped off at the dealer.
Old Nov 14, 2004 | 09:44 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i have seen a new maf clear up this code as well as P0171 which is the opposing bank running too lean. you can get a quote from jerryromenissan.com and enter MAXIMA for 12% discount or call dave burnette @ 888-254-6060. both are great sources with good prices. the part you will be receiving is an updated version which no one seems to have problems with.
Old Nov 14, 2004 | 01:21 PM
rdking's Avatar
Thanks, Sloppy I have a couple more questions since there is a updated maf for around $80 versus $400. Does the new meter need the ecm flash to work correctly? I thought I read a post, where someone just installed the new meter with no flash and the car ran ok.
Old Nov 14, 2004 | 02:42 PM
sloppymax's Avatar
it does not need the flash to work. i replaced mine w/o the flash and have had no issues just as many others. some had the reflash and some others skipped it and the consensus seems to be that it will not affect operation one way or the other.
Old Nov 15, 2004 | 04:56 AM
rdking's Avatar
I guess for $80 bucks I will give it a try. Its also an easy to change part. Anyone else care to comment on the 174 code MAF replacement.
Old Nov 15, 2004 | 06:10 AM
I30swimmer's Avatar
just put in premium gas. clean your throttle body .. and as deep as you can into your manifold.. disconnect the battery for a while (3 hours) and then put it all back together and then the code might be gone..
I had the same code like a week ago.. did all of what i just said and the code went away..
its a LOT cheaper than 80 bucks... so its your call
Old Nov 15, 2004 | 06:46 AM
jmal's Avatar
I just had two codes, P0171 and P0174...banks lean. A new MAF sensor cleared it right up, but I had it done at the dealer and they also re programmed the ECU (or updated it, or something). All set now.
Old Nov 17, 2004 | 03:22 PM
rdking's Avatar
Just a follow up I installed the new updated mass air meter and reset ecu. Have to give it a week or so to see if the code comes back. Paid $77.69 at local dealer he matched the best price I could find and had it in stock. If this takes care of my problem I will be very happy not hard to change and pretty cheap.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
