Driver side power window wont roll up.
Old Nov 15, 2004 | 04:50 PM
Slow Moe's Avatar
My drivers side power window decided not to roll up. My 36k warrantee ran out already. How can I tell if its the window motor? I opened the door panel up and checked all the wires hoping one of them was just loose. but all the connections were good. I reached inside to were the window motor is and it was really hot to the touch. I'd appreciate any suggestions or advice how to get the window up for tonight.
Thanks guys.
Old Nov 15, 2004 | 05:07 PM
gabe22's Avatar
its probably the motor.. my drivers side did the same....it was covered under my extended warranty.. well almost covered.. had to pay a $100 deductable...
Old Nov 15, 2004 | 09:54 PM
RollinLow's Avatar
Agreed about the motor. Mine just did it and it cost me like 200 for the motor. Replacing it is fairly easy tho.
Easiest way to check is pull the panel off again and jump the wires with a cordless drill battery and see if it moves at all.
Old Nov 16, 2004 | 05:34 PM
Slow Moe's Avatar
[QUOTE=RollinLow]Agreed about the motor. Mine just did it and it cost me like 200 for the motor. Replacing it is fairly easy tho.
I finally got a motor that works and I tried putting it on. It would be pretty easy but my window is down and inside the door making space really tight. I am about to give up and take it to a shop. Is there an easy way to take the glass window up?
fastcarny
May 18, 2020 10:40 AM
boomerbrian
Nov 8, 2015 05:10 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
mpbclutch33
Aug 21, 2015 06:09 AM
shaunkey1
Aug 18, 2015 10:09 PM
