Hood Vibration
Old Nov 16, 2004 | 12:55 PM
Noela's Avatar
Hood Vibration
Hi, I noticed my hoods vibrate when i reach freeway speeds....any one else notice this...
any cure for this - i understand it may need some adjustment and dealer wants to charge abt 1.5hrs labor for it...
best - Noela
Old Nov 16, 2004 | 12:56 PM
KCMC582's Avatar
http://maxima.theowensfamily.com/tsb/NTB02-005.pdf
Old Nov 16, 2004 | 01:51 PM
BP's Avatar
BP
i need to get this done. my hood was shaking so badly this morning i thought it would fly open. i had to pull over to make sure it was closed.
Old Nov 16, 2004 | 02:17 PM
MONTE 01&97 SE's Avatar
A minor adjustment to the hood stops helps tremondously although it will be just slightly unaligned, that is what most dealers do anyways. I think that problem was just an 02/03 issue my old 01 did'nt have that issue.
Old Nov 16, 2004 | 02:19 PM
NmexMAX's Avatar
dot dot dot ...
I've noticed it too, I knew in my 95, when it did it that bad, it wasn't closed so this one I don;t know what to think sometimes.
Old Nov 16, 2004 | 02:37 PM
ZeRo MaX's Avatar
I noticed it on my 00... thought it was a glitch of the max! :-x
Old Nov 16, 2004 | 02:46 PM
NmexMAX's Avatar
dot dot dot ...
4th gens didnt have that problem
Old Nov 16, 2004 | 06:20 PM
2k2kev's Avatar
It's chrome alright...
They also take off the insulation and squirt some liquid weld where the welds broke. That, and the hood-stop adjustment took care of mine.
Old Nov 16, 2004 | 09:19 PM
unrealii's Avatar
Is it easy to see where the welds broke when you take the insulation off? I was afraid of doing this tsb because I do not want to affect now the hood bends if it were to get into an accident (although having it not properly welded may not be a good thing either) if I were to apply the liquid glue incorrectly.
Old Nov 17, 2004 | 04:51 AM
2k2kev's Avatar
Yes, it's pretty easy to see where they broke, or you can take a putty knife and slip it between the hood brace and the hood and slide it along to see where it's loose.
Using a spatula/tongue depressor/putty knife
Broken weld
Also, nobody has mentioned the headlamp packs they put in... basically a piece of rubber gasket installed on top of the headlight housing that changes the direction of the airflow.
Old Nov 17, 2004 | 06:16 AM
F23A4's Avatar
After having it "fixed" @ purchase, I've just gotten used to it. So long as the locking mechanism keeps it in place, I'll just accept it as one of this car's quirks.
Does anyone know if this problem affects the A33 I30/I35?
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
leatherneck
Sep 30, 2015 09:16 PM
