Guidelines for aiming headlights on a 5.5
Old Nov 23, 2004 | 09:24 AM
TXT-1's Avatar
I know this was discussed before, but does anyone have a diagram or anything to give a standard on how high the headlights should be aimed? I was a dumba$$ and adjusted the lights up, but then lost track of where each side was aimed so now I have no idea where the lights should be aimed. Or if someone wanted to be really helpful, they could take a pic of there headlights against a flat surface from a set distance so I could replicate that. Thank you in advance for any input.
Old Nov 23, 2004 | 09:39 AM
Puppetmaster's Avatar
I found this using Google.... see if it helps...
http://www.autooptiks.com/aiming.html
Old Nov 23, 2004 | 09:42 AM
Edward Lee's Avatar
Start with them aimed toward the ground. Slowly raise the beam until the lower portion of the beam is at the point where you can see the ground from the drivers seat. This should be about three feet in front of the front bumper. You don't need light any closer to the car as you can't see the ground right in front of your car anyways.
I can snap a pic tonight and post if you wish.
Old Nov 23, 2004 | 10:21 AM
TXT-1's Avatar
Exactly what I was looking for. Thank you so much!
Old Nov 23, 2004 | 10:22 AM
TXT-1's Avatar
No picture necessary. Thank you for the advice!
Old Nov 23, 2004 | 10:33 AM
No problemo...
Apr 16, 2020 05:15 AM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Noela
Sep 26, 2015 08:22 AM
