Keyhole illumination
Old Nov 25, 2004 | 01:04 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Well, my ignition keyhole light has been down for a couple weeks and it was a bummer. Here is the link for the fix and some pics. Also, I installed a blue LED in place of the blue incandescent bulb. Can't wait for the evening.
The ignition keyhole light stopped working on my Maxima so the pictures that follow show the finished product.
It was determined that the problem lie in the Smart Entrance Control Unit. I didn't even entertain the idea of going to the dealer and seeing how much that would cost. Without asking I knew it would be too much.
When the light was supposed to come on the voltage was supposed to go from 12V to 0V. However, the ground was reading 12 volts instead of 0 volts when lit. So, I decided to ground Pin 30 to Pin 32, the Front Step Lamps. The pink wire you see is the connection I made to enable the keyhole light to come on. Now the keyhole lights up when the doors are opened. The keyhole light essetianlly operates under the same conditions as the Step Lamps, comes on when any door is opened.
Old Nov 25, 2004 | 02:07 PM
ZIPPIN's Avatar
Mauja He Mauja
wanna see pics of the leds in action
Old Nov 25, 2004 | 03:45 PM
Epacy's Avatar
Yeah I should get some pics of the LEDs tonight.
Old Nov 25, 2004 | 05:22 PM
Epacy's Avatar
Blueness
Ok. Here are some pics of the blue LED in the keyhole ignition light instead of the incandescent. There are also more pics on my webpage.
Old Nov 25, 2004 | 06:53 PM
djfrestyl's Avatar
Suspension Yoda
i really need to learn about leds and soldering and resistors....
looks great - good job on the leds and way to figure out a simple problem
Old Nov 25, 2004 | 07:05 PM
irish44j's Avatar
retired moderator
looks good man.... a big improvement over my "ghetto" (remove condom, use sharpie) blue key ring surround!!
Old Nov 25, 2004 | 08:14 PM
Epacy's Avatar
Just glad to have the dash back together.
Old Nov 26, 2004 | 07:36 AM
Bl_asd's Avatar
y ur a/c doesn't light up?
Old Nov 26, 2004 | 10:02 AM
Epacy's Avatar
I broke one of the bulbs. Have been looking for a replacement. Anyone know where to buy those?
Old Nov 26, 2004 | 10:15 AM
Komax's Avatar
I have a question. My "recycle" button and "Mode" button don't light up in my climate control. Is this a bulb issue or an LED issue?
Old Nov 26, 2004 | 12:40 PM
Epacy's Avatar
Bulb. I don't believe there are factory LEDs in your digital climate control unless you changed that.
gavin68
Sep 18, 2021 12:36 PM
jc53
Oct 12, 2015 05:12 AM
BobTX10
Oct 7, 2015 08:43 AM
kadespraggins
Sep 14, 2015 12:04 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
