Power Window Switch
Old Dec 8, 2004 | 05:54 PM
Oldguy_Longley's Avatar
Power Window Switch
Look as I might in past threads I can't seem to find a past-post on the sugject. Front passenger power window switch is "dangling" down insde the door panel. I supect, at very least, i need to remove the armrest panel to re-insert the switch in it's "hole" - or remove the door panel completly
A how-to would be appreciated. I recall a fairly detailed "How-to" at one time (Had to do with re-lighting tyhe switches if I recall).
Novice needing help
JimL
2000 Maxima SE
Black on Black
Old Dec 8, 2004 | 06:17 PM
WaHooo! Found (er... googled) my own answer!
http://www.cardomain.com/memberpage/479058/3
Went out in the cold dark outside, and Badda Boom Budda Bing - Power Window switch is in its proper place
Old Jan 25, 2008 | 02:31 PM
2002 Maxima SE's Avatar
After removing the screw, are there any pressure clips holding this to the door? If so, where should I pry up to remove the power window switch cover?
Old Jan 25, 2008 | 04:20 PM
No pressure clips wrap a regular flat blade screw driver in a cloth and gentle pry up. Strat at one end, say away from switches. Work your fingers in underneath and continue around untill in pops out
Old Jan 25, 2008 | 05:36 PM
Thanks for the clarification. I did find some pressure clips on the rear inside part of the panel.
The front (nearest the inner door handle) has a hook pointed toward the front of the car. There are pressure clips on the inside (closest to the door) part of the panel. Like Oldguy_Longley says, lift up from the back. Once the back is up you want to pull back (toward the rear of the car) and up working your finger toward the front.
maximusrising
Sep 4, 2015 06:31 PM
