Climate Control Bulb Replacment?
Old Dec 11, 2004 | 12:10 PM
026speedmax's Avatar
I havent seen any threads for bulb replacment on the manual climate control on the 02 max, any one know anything about this? I have a few bulbs out on mine mostly on the entire left side of the unit, and its anoying, Any Advice, THanks.
Old Dec 11, 2004 | 07:27 PM
turbozx's Avatar
You need to order the bulbs from nissan approx 1.00 ea I think it takes 5 just replace them all while you have the unit out.
Old Dec 12, 2004 | 01:52 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Which light is out? If it's the indicator bulbs beneath the buttons that is going to be a bit more involved as it will require that you solder in new LEDs. However, if it the actual panel backlight, it's a bit easier. There are 3 bayonet housings for the backlighting that are simply plug and play...you may simply need to re-screw them in, they may have come loose. I would take it apart and diagnose the problem before dumping money into it.
Old Dec 12, 2004 | 01:54 PM
Originally Posted by turbozx
I think...
Don't think. If you don't know the answer, DON'T suggest what you THINK may be the fix to the problem.
Old Dec 13, 2004 | 06:21 AM
its the backlighting, but the indicators below the air position selector are all at different depths, some have fallen back further than others, i guess i will just have to pull it out and apart to see whats up, I was also wondering if anyone knows exactly how to install the digi unit, i know it requires the addition of some sensers, 4 i belive, but has anyone done it yet? and if so can anyone provide me with a parts list or install instructions?
Old Dec 13, 2004 | 11:35 AM
turbozx's Avatar
I didn't hesitate on what the problem was i just forgot how may bulbs were in the unit because i just had to do it a month ago. And i don't think dumping 5 dollars into someting that you have to pull apart is a waste of time. Especially when it's a common problem.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
