will these rims wit on a stock 2001 GXE
Old Dec 11, 2004 | 09:25 PM
BlkShadow01
18" (215/35/18)
Will that size fit nicely or would it rub up?
Old Dec 11, 2004 | 09:26 PM
Loe max's Avatar
I dont believe so, but that aspect ratio is a bit low and your speedo will be goofy.
Old Dec 11, 2004 | 09:57 PM
Audtatious's Avatar
Bandwagon Lover
Nope, no problems unless your rim has the wrong offset. Why 215/35's? Thin tire with no rebound. Hope you don't have a lot of potholes in your town.
Old Dec 11, 2004 | 10:03 PM
frankd121's Avatar
Yeah...i'd go with some 235's, 225's at least
Old Dec 11, 2004 | 10:10 PM
scopium
215 is waaaayy to skiny for 18" tires
at least 235 .. best is 245
Old Dec 12, 2004 | 08:04 AM
Y2KMaxGXE-R's Avatar
the correct size for our cars is 235x40R18. The 215s you are looking at are for compacts
Old Dec 12, 2004 | 10:28 AM
BlkShadow01
but its a package 4 rims and 4 tires for 1099 ..wat should i do then if i want those rims.. also can i get bigger tires for the same 18' rims? and wat does
215/25 mean?
Old Dec 12, 2004 | 10:30 AM
djfrestyl's Avatar
Suspension Yoda
then the package is not paired for your car correctly. make sure the offset is correct and if that is the package for your car, pay for the wider tires
Old Dec 12, 2004 | 12:46 PM
NewLoveI30's Avatar
215/25 mean?
215 is the width of the tire in mm.
25 would mean that the sidewall is 25% of the tire width. (25 would be like no tire btw.)
If they dont have the correct size, just buy the wheels and pay for your own, correctly sized tire.
Old Dec 12, 2004 | 01:01 PM
Audtatious's Avatar
Bandwagon Lover
I would suggest upgrading the tires. I highly doubt that tire package has tires included that have the appropriate load rating. 215-35 rubber bands are a poor choice for a Maxi, IMO.
Old Dec 13, 2004 | 05:12 AM
215/25 mean?
there are two things you might want to do. A) buy USED, B) save $150 more. Man the wheels are your safety, you dont want to put your life on the line for $100
9aj9
Apr 5, 2020 12:11 AM
QueensMAX
Sep 15, 2015 04:14 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
