Help with yearly service maintenance?
Old Dec 12, 2004 | 03:00 PM
Jinro's Avatar
Just wondering what the yearly service maintenance would be on a max.
So far I know...
3 months/3k miles oil change and air filter
6 months wiper blades
Haha that's all I know!
Anyways, I went to get an oil change and the guy said that I needed a automatic transmission flush. Probably would cost about $100. Should I do this?
Also, he said I should change my brake pads and get a coolant flush (for heater and AC) every 6 months.
Get a tire rotation and wheel balance(whatever that is) every 3 months.
Change the spark plugs every year.
Change my serpentine belt every year.
There was also changing PCV valve, fuel filters, timing belts, fuel system cleaner, antifreeze...
What else do you guys do on your max every year?
My car has about 62,000 miles on it.
Just want to know what is recommended by you guys so I dont have to do all of that above.
Thanks a lot!
Old Dec 12, 2004 | 03:01 PM
crispykid717's Avatar
Bigger than Jesus
Did you get a service manual when you got the car? Check that out.
Old Dec 12, 2004 | 07:26 PM
Jinro's Avatar
Nope I do not have a service manual...
Old Dec 12, 2004 | 07:58 PM
scopium
oil change every 3500
spark plugs.. every 100k
tranny flush every 30k
pads .. depends... have to check
coolant flush not really necessary
tire rotation every 9k
keep that up and your car will be in good condition
Old Dec 13, 2004 | 05:25 AM
schernov's Avatar
go to Nissanusa.com to the service section, put in your milage and it will tell you.
Old Dec 13, 2004 | 11:05 AM
mike_747's Avatar
maintainance
Every two years or 30K, change coolant, replace trans fluid if automatic. Other than that rotate tires every 6-8k miles and change oil every 3k. Change air filter every 2 years.
that's about it - except for repairs.
Old Dec 14, 2004 | 06:18 PM
Jinro's Avatar
Thanks for all the feedback guys...
I'll check into what you guys said.
Old Dec 14, 2004 | 07:49 PM
AKANeedles's Avatar
Make sure you do most of it yourself.You'll save alot of money.
Old Sep 27, 2007 | 05:44 AM
Atlpinoy's Avatar
service guy told me to do brake flush is that necessary?
Old Sep 27, 2007 | 06:41 AM
NmexMAX's Avatar
dot dot dot ...
Only if the fluid is low or horrifically dirty.
Old Sep 27, 2007 | 07:11 AM
NJ Devils Fan's Avatar
The guy who told you that is an idiot. Our cars don't have timing belts, we have timing chains. Changing the spark plugs every year is just a waste and pointless as well as the antifreeze. Any way to nickle and dime someone they will.
Old Sep 27, 2007 | 01:18 PM
twiggy144's Avatar
I would change the brake fluid every 2-3 years. It is inexpensive and it prevents calipers from rusting and seizing.
Old Sep 27, 2007 | 03:02 PM
ptviperz's Avatar
Yep
Old Sep 27, 2007 | 04:30 PM
NmexMAX's Avatar
dot dot dot ...
2-3 years = x miles?
Old Sep 27, 2007 | 05:23 PM
Maxgig's Avatar
+1 to what everyone said. But IMO I think you should make your schedule based on how you drive your car. I personally change my oil every 5k miles, change my coolant every two yrs, rotate my tires every 2nd oil change, (check my brake pads when I do the rotation). Cabin filter every 10k miles, spark plugs at 100k miles (50,850) so far. Change transmission fluid every 30k miles, wiper blades every winter. I've never changed my brake fluid but will definitely start since on my former Max the rear brake calipers did sieze up on me after 130k miles. Also you can do most of the work yourself with the right tools. Just make yourself a maintenance book on your computer with dates, miles, what was done and don't forget to keep your receipts, this will be extremely helpful if you ever decide to sell your car.
Old Sep 28, 2007 | 03:00 AM
lalaMAX's Avatar
every:6000-7000km(3-4 month)
techron fuel injector cleaner before oil change
oil change (currently castrol syntec will use PP later)with 9E000 oil filter
power steering fulid (turkey baster) with mobil 1 ATF
every:12000-14000km (half yr)
ATF drain and fill with mobil 1 ATF
Tire rotate
every year(never care about the km):
coolant drain and fill with Nissan coolant
break fluid with Castrol LMA<-- not sure
clean intake
de-carbon
wash my KN filter
clean MAF with maf cleaner
umm could not think of more at the moment...
coil and plug changed at 60000km due to random misfiring...with updated coil and NGK Iradium
ya just changed my both belts...(first time in 7 yrs, only 78000km on the clock)
changed break half years ago:
front Pad: Hawk HPS
Rotor: RTP slotted form GD
rear Pad: Monor
Rotor: still the original one, only resurfaced when pad change...
daz it...
maybe u guys think its over kill, but not to me since i enjoy working on my cars, and i rather save all the labor money so i can do it more often...
Old Sep 28, 2007 | 03:58 AM
ptviperz's Avatar
Mileage isn't the problem, it's the amount of water that gets in the fluid. Every 3 years seems reasonable. Calipers cost more than brake fluid
Old Sep 28, 2007 | 06:39 AM
NmexMAX's Avatar
dot dot dot ...
Maybe I should begin this practice.
Old Sep 28, 2007 | 09:22 AM
SoonerFan's Avatar
Cletus
free owners manual download
http://www.nissan-techinfo.com/nissa...p?dept%5Fid=37
Old Sep 28, 2007 | 10:36 AM
NmexMAX's Avatar
dot dot dot ...
I never noticed this until recently, but my 95 gives a much better look at the maintenance schedule. Essentially a spreadsheet w/miles and service to be done.
These days, they do not include this with the standard owners manual
Old Sep 28, 2007 | 10:56 AM
SoonerFan's Avatar
Cletus
mine had that spreadsheet
it was a separate maintenance booklet
Old Sep 28, 2007 | 12:35 PM
sirjinx21jay's Avatar
I didnt know that the 2000 - 2003 had timing chains???? are you sure??? or is it just the 2002 - 2003 model years ????
Old Sep 28, 2007 | 12:41 PM
NmexMAX's Avatar
dot dot dot ...
95-07 have timing chains.
All VQ's. And yes, we're sure.
captchaos
Mar 15, 2016 12:18 PM
Steven Orozco
Sep 12, 2015 10:41 PM
Jay556
Sep 12, 2015 05:50 PM
crazyespn
Sep 3, 2015 01:30 PM
