Bad Coils?? / P0300 - Multiple Cylinder Misfire Detected
Dec 12, 2004 | 04:41 PM
Hey Guys I pulled this code (P0300 - Multiple Cylinder Misfire Detected) today after the service engine soon light came on. I'm guessing this has to do with the coils??? If so how long are coils covered under warranty?
Dec 12, 2004 | 07:41 PM
ive seen a few people get it covered under powertrain up to 60k but most were only covered 3yr/36k. most likely is the coils since it mulitple misfire. you havent changed or had the plugs changed recently have you?
Dec 12, 2004 | 08:08 PM
Yea I actually changed the plugs last month. I got a code saying a misfire on cylinder 2 so I decided to go ahead and change the plugs. Once I did the SES light went off and hadn't come back on till today.
Dec 13, 2004 | 05:25 AM
Quote: Yea I actually changed the plugs last month. I got a code saying a misfire on cylinder 2 so I decided to go ahead and change the plugs. Once I did the SES light went off and hadn't come back on till today.
did you happen to use bosch plugs or some other brand than NGK?
Dec 13, 2004 | 09:03 AM
Quote: did you happen to use bosch plugs or some other brand than NGK?
Nope. I only use NGK.
Dec 13, 2004 | 09:31 AM
I gto that same code and it was my spark plugs went bad and also my MAF went out nothing to do with my coils cuz i had just replaced them
Dec 13, 2004 | 10:51 AM
Quote: I gto that same code and it was my spark plugs went bad and also my MAF went out nothing to do with my coils cuz i had just replaced them
hmmmm. I don't think it would be the plugs (or I hope not), they are brand new. It's at the dealership right now, so I guess I'll know what it is later today.
Dec 13, 2004 | 11:00 AM
shouldnt be the plugs if they are ngk and the gap either wasnt set correctly or came out the factory spec. let us know what it is.
Dec 13, 2004 | 11:32 AM
It's most likely do to an air leak or bad MAF.
You'll get that code from running lean at idle with an air leak. Check all of the intake plumbing for tightness, then clear the code. If it comes back I would then look at the MAF, the coils would be the last thing to look at.
Dec 13, 2004 | 12:25 PM
I set the gap correctly so it shouldn't be that. I also checked all the intake plumbing last night. Everything was good. I guess it may be a bad MAF. Hopefully the dealership will call soon.
Dec 13, 2004 | 12:59 PM
This is the list of possible causes from the FSM.
* Improper spark plug
* Insufficient compression
* Incorrect fuel pressure
* The injector circuit is open or shorted
* Injectors
* Intake air leak
* The ignition secondary circuit is open or shorted
* Lack of fuel
* Drive plate or flywheel
* Heated oxygen sensor 1
* Incorrect PCV hose connection
Also check the PCV.
Dec 13, 2004 | 01:31 PM
* Injectors
* Intake air leak
* Lack of fuel
Also check the PCV.
The dealership just called and said it could be a number of things. They said they checked everything and it's all cool so they just cleared the code. Hopefully it won't come back on.
