Y-Pipe Installation and Emissions Testing
Old Dec 12, 2004 | 01:33 PM
5thgen2nr's Avatar
Originally Posted by UMD_MaxSE
Installing a Y-pipe, or intermediate pipe, will not cause you to fail emissions testing given that you test the car when it is warmed up and that you have not removed the main cat. The Y-pipe removes the precat that is built into the stock pipe. The purpose of the precat is to cut down on emissions when the car is cold since it takes some time for the larger main cat to warm up to operating temperatures. So, if the precat is removed, the only time you may possibly fail emissions is when the car is cold. If the car is running at normal operating temperatures and you have your main cat in place, you should not fail emissions testing. If a visual inspection is involved and the inspector knows what to look for, then that changes the story
I am going to get really specific here; will I fail emissions if I have a CA spec y-pipe couple with a random tech high flow cat? Or do I need an OEM cat in order to pass the emissions test?
JRod28
Dec 29, 2023 09:56 PM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
