Problem with 20's??? HELP!
Old Dec 13, 2004 | 12:14 PM
Maxima Girl's Avatar
Ok, here is the deal,
I have 20" rims on my 5th gen and I just dropped it with tokico illumina suspension and vogtland springs.... problem is the SLIGHTEST bump and my rear left tire hits something hard! But it's only that tire! The other side has never ever hit!?! The offset on the rear is 20 and the front is 10 is that a problem since it's a staggered off set? I am just looking for suggestions because it's so slammed I can't even drive anywhere now....
Old Dec 13, 2004 | 02:05 PM
juice's Avatar
You could try those rubber spring stops (or whatever they are called) they sell at PepBoys. It is basically a piece of rubber you place in between the coils of the rear springs to keep it from compressing to much.
Old Dec 13, 2004 | 02:17 PM
NYC TAR's Avatar
I remember that you have to trim little piece off the rear left fender, when people installed G35 rims.
Old Dec 13, 2004 | 02:20 PM
zax 20th ae's Avatar
Its The Rear Passenger Side Isint It...
Old Dec 13, 2004 | 02:22 PM
If So Its Possibe That The Gas Tank Filler Tube Were You Put The Gas Nozzle In To Fuel Up, Might Be Rubbing The Top Edge Of The Tire My Cousin Had That Problem...
Old Dec 13, 2004 | 02:58 PM
SoonerFan's Avatar
Cletus
the real problem is 20s on a maxima (that is dropped!!)
what did you expect?
Old Dec 13, 2004 | 03:09 PM
† ErV †
So Is When People Try To Type In All Caps. Like This.
Old Dec 13, 2004 | 03:35 PM
AKANeedles's Avatar
Are you a pimp?
Old Dec 13, 2004 | 03:59 PM
SoonerFan's Avatar
Cletus
Originally Posted by AKANeedles
Are you a pimp?
Old Dec 13, 2004 | 04:04 PM
NYPD-Arnold's Avatar
Z
Brooke...marry me.
(This is my contribution to the thread)
Old Dec 13, 2004 | 04:24 PM
Yaco_Max's Avatar
Wow Arnold......... She's trying to get help !
Not more troubles!!! I'm just kidding with you. BRO!
Old Dec 13, 2004 | 04:48 PM
No I am definately no pimp that's for sure! Sorry can't marry you honey because I work too much we'd never see each other... anyways guys thanks for any ideas ya might have its just frustrating to hear it hit. I think since it's only the rear right side that something may be wrong with my axel or frame??? I may just have to put my rear stock springs back on...
Yaco_Max's Avatar
I know what do you mean!
Girl I pulled your pics ...
Cool car!!!!!
Old Dec 13, 2004 | 05:03 PM
JdoubleOe703's Avatar
teddibear703
u need to shave off a bit where the bodypanel meets the rear bumper on the inner well... it sticks out a bit and thats where the rub is... just run your hand along the fender and you will feel it...
Old Dec 13, 2004 | 05:48 PM
Z
I can cook* and clean the house**.
*Buy more mods
**Clean the car
Old Dec 13, 2004 | 05:51 PM
BlkShadow01
hahaha, ya you're blingin now with your 20's DAWG!! why 20's!?!? too look stupid? hmmm..get 24's next time and lower it more, then u'd deff b pimpin..neways shouldn't u b washin the dishes not rollin on 20's?
hahaha jus messin
kinda
Old Dec 13, 2004 | 06:13 PM
mdloops's Avatar
Definately. The suspension was designed for 17s and 16s and you decided to go 3-4 inches bigger, slam it, and didn't expect problems? Funny thread. We should have a special part of the forums for all these threads lately. "I put 30 inch rims on my max, dropped it 4 inches, and it rides poor now?". "My tranny died! I only ran 150 shot of nitrous through it!"
My suggestion is to get STOCK size rims and not drop it to the ground
Mark
Old Dec 13, 2004 | 06:31 PM
AKANeedles's Avatar
There pimp wheels soonerfan.Not for the Max.
Old Dec 13, 2004 | 06:32 PM
ibag8rfan's Avatar
hahaha jus messin
kinda
Great post moron. I wouldn't drop the car more than an 1.5" with 20's.
Edit: Your car looks hot, and you are beautiful.
Old Dec 13, 2004 | 06:34 PM
SoonerFan's Avatar
Cletus
i agree...thought you were talking to me
Old Dec 13, 2004 | 06:49 PM
myktek's Avatar
what does the bump soudn like it... is it like a scratching sound??? if it is, it's the little piece of the fender that stick in....prob hitting that...idunno
Old Dec 13, 2004 | 06:53 PM
Cutler's Avatar
Those offsets are wrong, should be more like 35-40mm, recheck the offsets and it may require a rolling of the rear fenders....
Old Dec 13, 2004 | 07:16 PM
Nathan's Avatar
Holy, some of you sounds like immature elementary school children. Grow up!
As for your rubbing issues, you're most likely rubbing the fender where the fender curves in. Your offsets are way off. They should be no lower than 35mm's, or else you'll be asking for trouble.
I have 19's and tend to rub the rear passenger side fender much more than I do the rear drivers side. All I can suggest is getting your fenders rolled.
Old Dec 13, 2004 | 07:20 PM
irish44j's Avatar
retired moderator
OFFSET. Even with 17's you're gonna rub if the rims are a 20 and 10 offset. The max offset you can really run on the back without rubbing is MAYBE 30, but more likely about 35. How far out are those rims sticking out from the wheel wells????
Old Dec 13, 2004 | 07:40 PM
Ammi's Avatar
350 Detroit Muscle
How wide are those 20s? You can't be running 20s w/ 10mm offset.
Old Dec 13, 2004 | 07:45 PM
BlkShadow01
Gettin bigger/huge rims only makes the car peform poor and doesn't even look good. I'd stick with 17's or 18's at most.
Old Dec 13, 2004 | 08:42 PM
Blk2kMAXSE's Avatar
i had the same problem. my problem was on the rear passenger side. tire would rub against the lip where the rear bumper is connected to the car. had to beat it in a lil. try cleaning in there really good, put some tire shine on the tires and go for a short drive. see where the tire shine rubs off to see where its rubbing.
hope this helps,
Lam
Old Dec 14, 2004 | 07:46 AM
Mass_Media's Avatar
Mass_Media™
Here is the answer!!!
Get some airbags!!! Masa (don't know if you know him) had the same problem with his Lexus he dropped it with 20's and his front tires where rubbing..he got airbags instead and it solved the problem....I don't know what was rubbing....and even if airbags would help....but it would look sick to see a max with air bags....hehehehe
Old Dec 14, 2004 | 07:58 AM
Blk2kMAXSE's Avatar
ummmm, i have air bags..... still had the problem.
Old Dec 14, 2004 | 08:35 AM
tmaculate1's Avatar
holy shiot, she is fine. i need a girl like her.
Old Dec 14, 2004 | 04:21 PM
Thanks so much for the help. I rolled my fenders before I ever put the 20's on. I will take ya'lls suggestions and try them out tomorrow! I will let you know who's ideas worked! Thanks again for all the concern and input! -MG
Old Dec 14, 2004 | 08:01 PM
PEARLDIAMOND's Avatar
What rims are look better 01 or 02-03
Old Dec 14, 2004 | 10:43 PM
teddibear703
hehe, thats why i went w/ bags.... raise it up high while cruisin....
Old Dec 15, 2004 | 02:15 PM
02SEMAxIMA's Avatar
Do you have a close up pic of the way the rims sit before the drop? Mine was on 20's for a week and everyone that seen it said it looked kind of funny. Which made no sense because the rims were stolen off the car!
Old Dec 15, 2004 | 02:53 PM
The only pics I have are on my website www.cardomain.com/id/themaximagirl
Yeah they do look funny on 20's because the front sits higher and the back is low when they have stock suspension. Plus they are so high they look like they are going four-wheelin. It looks much better now that it is dropped but makes that damn noise!
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
