Car begins to shake at 60-70mph
Old Dec 13, 2004 | 10:29 PM
-Red-'s Avatar
Started happening recently, I notice a severe shudder when I hit about 60-65 which seems to disappear when I reach 80. At one point, I thought one of the damn wheels is about to fall off.
I'm not entirely sure what to make of it; the only thing I can think of is that wheels may need to be balanced. Is there anything else I should look into?
Old Dec 13, 2004 | 10:33 PM
03tgtmaxima's Avatar
alignment might help my moms car did he same thing balanced rotated and aligned and t stoped
Old Dec 13, 2004 | 11:25 PM
frankd121's Avatar
alignment and wheel balance.
Old Dec 14, 2004 | 07:07 AM
-Red-'s Avatar
Aside from alignment and balance, anything else I need to look for?
Old Dec 14, 2004 | 07:56 AM
00Max00's Avatar
check for defective tie rod
Old Dec 14, 2004 | 08:00 AM
Corelventura's Avatar
Might want to check for brake pads also, they might have worn out.
Old Dec 14, 2004 | 08:16 AM
spirilis's Avatar
worn out brake pads shouldn't cause a shudder at high speed unless you are braking.
Old Dec 14, 2004 | 09:14 AM
MiniRX7's Avatar
also check for rim damage.
in my case, my winter rims are perfectly aligned but it is not hub centric!
Old Dec 14, 2004 | 11:41 AM
dizmax96's Avatar
check your wheels and make sure your wheels are on tight..
Old Dec 14, 2004 | 02:03 PM
ddpack's Avatar
Typically at that MPH it is a wheel balance problem. Sometimes the weights fall off the rims, make sure weights are on. Usually a tie rod shimmies all the time until you get going faster. You should also check and make sure you don't have any radial ply separation.
alixc
Aug 11, 2020 01:48 PM
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
jhontelj
Aug 17, 2015 04:07 AM
MikesChevelle
Aug 10, 2015 10:53 AM
