Transponder Key programming
Old Dec 14, 2004 | 12:20 PM
import_rcr's Avatar
I only have one key for my '01' AE so I ordered a spare from e-bay. My question is, is there a do it yourself programming method or does dealer have to do it? Also will my current key and the new key work together or will the programming make my original not work? Any help on this is greatly appreciated.
Old Dec 14, 2004 | 12:50 PM
Rogo02SE's Avatar
You need to have it programmed by a locksmith or a dealer.
At this time I don't belive there is a DIY method.
Old Dec 14, 2004 | 12:52 PM
Ivanhoe's Avatar
- The deaker (or a locksmith) has to do it
- When you go, all the keys you want to start you car have to be with you
- Once complete, all the keys you provided to the dealer will work
Old Dec 15, 2004 | 09:16 PM
import_rcr's Avatar
Thank for the help. I was hoping to keep a few of my hard earned $$$ out of their pockets but o'well.
Old Dec 15, 2004 | 09:45 PM
louisvuitton500
u shouldn't order the key. I almost did the same thing but I called a local locksmith before I ordered it. I am not sure about upper Marlboro area but there's only couple companies that does the transponder keys in Rockville. Don't get it cut from a local locksmith because the cut is not the same as your original key but the key still works. I got my 1st spare cut from this company called Armen's locksmith #301-963-8100. Cut, programing, plus the key is $75 same if I had my own key. I think he charge the lowest in the area. I got my 2nd key done at the dealer for $110 total cause I got hook up. I think $45 per key but $60 to program up to 3 keys. Lucky I am using the 1st for a remote start or I am stuck with this ugly key that's hard as hell to pull out from my ignition. If u are just using it for emergencies, just call the # I gave u. If u planning to use the key often, go to the dealer and get 2 keys and have it programed for lil bit over $200. That guy Armen does in-home service, so u don't have to come down to Rockville. Very nice guy, graved me an extra key for free.
Old Dec 15, 2004 | 09:47 PM
Epacy's Avatar
Unsuccesful STL Coordinator
You do not need to go the dealer. Any locksmith worth his salt will be able to help you out. It is about half the cost of going to the dealer. Like mentioned, all keys need to be reprogrammed. You can however do the remotes by yourself. Although I had to do some modifications to mine to get them to work, regardless of the "bible" procedure.
Old Dec 15, 2004 | 09:59 PM
louisvuitton500
But we live in MD. We don't have many bright ppl that charges low for any type of service. My locksmith choped that key up like it's fish.....now I am left w/ a metal fish bone with the word Ilco on it.
Old Dec 16, 2004 | 07:20 AM
Epacy's Avatar
Then he owes yours ***.
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
QueensMAX
Sep 15, 2015 04:14 AM
