how to install rear valance?
Old Dec 18, 2004 | 09:04 AM
nwmrktmax's Avatar
Hi,I'm sorry if this was brought up before or is a repost but the search function doesn't work for me so.How did you guys install your rear valance?
I just got mine painted and want to do it the right way.Btw I live in Ontario where it snows if that matters.
Old Dec 18, 2004 | 06:14 PM
nwmrktmax's Avatar
Bump,just want to know how to install it right.I was thinking double sided tape and screws?
Old Dec 18, 2004 | 07:00 PM
ToYLeT902's Avatar
JET Speed Lab
3M double sided molding tape (the red one), 2 screws on each side (4 total). Thats one way of doing it.
its better to do it in a heated garage. Make sure your bumper is clean, and you heat up the tape with a heat gun or a hair dryer so the tape sticks better. Then screw in the 2 screws on each side. (your rear wheels might get in the way)
Old Dec 18, 2004 | 07:07 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Will you drill the holes before painting or after. It sounds stupid but I was reading the Stillen instruction and it says to do the drilling after painting.. Does it makes sense?????
Old Dec 18, 2004 | 07:23 PM
ToYLeT902's Avatar
JET Speed Lab
Either way is fine really. You can use sheet metal screws, or for a cleaner look you can use rivets.
Old Dec 18, 2004 | 11:42 PM
thomasd cook's Avatar
I used rivets on mine and silicone. I did have to remove the rear wheels to drill a pilot hole for the rivet. It just slides right on.
Old Dec 19, 2004 | 06:34 AM
Ammi's Avatar
350 Detroit Muscle
Same here. Removed the wheels, drilled few holes and used rivets.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
ef9
Aug 27, 2015 07:21 AM
maxipower
Aug 21, 2015 11:10 AM
Maxboy23
Aug 20, 2015 09:33 AM
