E-Brake Light
Old Dec 20, 2004 | 06:32 PM
compnurd2K2MAX's Avatar
E-Brake Light
My e-brake light is flashing everynow and then and seems to go away after i tap the brakes. Could it be that my rear brakes are in need of replacement?
Old Dec 20, 2004 | 10:29 PM
thomasd cook's Avatar
Check your brake fluid level. If not that then I'd say your pads need changing.
Old Dec 20, 2004 | 10:33 PM
Ferbs02SMMax's Avatar
^^ is right.
A couple days ago, my brake warning light came on. I checked w/the owners manual, checked the brake fluid reservoir, and sure enough it was low. I bought a little container of DOT3 brake fluid, added it to the "Max" line and the light went off. No biggie. $1.25 for the brake fluid, by the way.
Good luck.
Old Dec 21, 2004 | 03:01 PM
doesnt your brake liquid going low indicate that you may need new brakes?
Old Dec 21, 2004 | 03:02 PM
CCS2k1Max's Avatar
Read your owners manual!!!
Old Dec 21, 2004 | 05:56 PM
Menasor's Avatar
Yes.
I would check your brakes if the fluid is low.
Old Jan 8, 2005 | 09:06 AM
Just wanted to post that I had to change out my pads this week. If you have a brake light I would definately check the pads before adding more fluid. My pads were so bad there was no padding left at all on 2 of my front pads. The pads were on the back side of the rotor which made them impossible to see. I recommend taking the entire wheel off to inspect.
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
