Door Open Warning Light malfunction
Old Dec 20, 2004 | 09:30 PM
jemery's Avatar
For some reason, on my 2000 Maxima, the door open warning light has recently started staying on even when all doors are closed. This has the side effect of interior lights staying on even when the ignition is off. Any ideas what could be causing this?
Old Dec 20, 2004 | 09:51 PM
Menasor's Avatar
I am not sure what might be causing it to come on...but check your trunk maybe that could cause it to come on. Do you have an aftermarket alarm system?
Old Dec 20, 2004 | 10:21 PM
MiniRX7's Avatar
The door pin switch is corroded and shorting out.
Or it may be sticking. Its not expensive to replace it. You just need to figure out which door.
Old Dec 21, 2004 | 09:31 AM
jemery's Avatar
No on the alarm system. I did check the trunk and it is also closed. Thanks for the suggestion though!
Old Dec 21, 2004 | 01:07 PM
jemery's Avatar
Thanks! It turns out the driver side pin switch was broken. I am guessing it may have been caused by the seatbelt getting caught in the door which happens on occasion.
Thanks for your help.
vingodine
45
May 21, 2016 12:46 PM
Gildarts
Aug 31, 2015 07:10 AM
rbaker100
Aug 28, 2015 08:11 PM
Gsantos79
Aug 8, 2015 07:41 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
