In a weird circle with ignition coils,codes / pls help
Old Dec 22, 2004 | 02:45 PM
ninja_7502001's Avatar
Check engine light is on, got following code P1320 and P0302.
Changed ignition coil and spark plug on cylinder 2. Still the same problem - car shakes???? and service engine light is on with the same code.
Thx
Old Dec 22, 2004 | 02:58 PM
sergeo7's Avatar
Thx
you need to change all of them, because of the bad design by nissan. All coil will go bad. And sometimes the code doesn't show up for other coils.
Old Dec 22, 2004 | 03:22 PM
I need to know this for 100% if thats the issue. Not a cheap fix, who do you recomend for parts and if you have instruction on how to change them - pls post. I changed ignition coil and spark plug on cylinder 2 and I only see 2 4 6 ignition coils for cylinders on the top??
Old Dec 22, 2004 | 04:34 PM
aussie983's Avatar
Follow this HowTo:
http://www.nissanx.net/tanman/
Just take off all the coils and replace them instead. Leave the plugs there.
Old Dec 22, 2004 | 06:43 PM
Great info, just to make sure cylinder #2 would be under the Nissan cover in the middle???
Old Dec 22, 2004 | 07:45 PM
RsMaxMaggie's Avatar
Engineer/Inventor/Maximanian
I'm not trying to jump in here if you have the problem solved, but I found that by reading the plugs I was able to isolate the bad ignition coil. I replaced that one coil about 10K miles ago and have not had any bucking since then! In my case it was cylinder #6, the hardest one to reach. What I saw on the plug was more erosion of the electrode compared to the other plugs! Oh yeah, I did replace the plugs at the same time as the coil. So far the other coils are holding up fine!
Old Dec 22, 2004 | 09:10 PM
Where is Cylinder 2 located?
Old Dec 23, 2004 | 05:00 AM
The cylinders are counted from the driver's side front as one, 2 is middle front, 4 is passenger rear, 6 is driver rear. Hope that helps!
Old Dec 23, 2004 | 09:33 AM
sergeo7's Avatar
You might be fine for a while, but you performance is still no as with revised coils. New coils have silver dot on them. They produce more spark. My coils we failing slowly, one day the worked, one day car started to misfire. After changing all of them I noticed a boost in performance.
As far as where to get new coils, call DAVEB. He sells them for $50 a piece.
Old Dec 23, 2004 | 10:30 AM
dmplus's Avatar
Um some of the orgers may be giving your false info. My cylinder #2 coil went out like yours and I replaced it. It's on the radiator side of the engine (under the nissan cover) and furthest towards the passenger side of the car. It is NOT the middle coil. If you're standing at the front of the car looking at the engine the cylinders should be like this:
1 3 5
2 4 6
So I replaced my coil on cyl 2 and the shaking immedialtly went away and the cel turned off in the next few days.
If you replaced the middle coil you probably changed out cyl 4, which is why you still have the problem
Old Dec 23, 2004 | 04:49 PM
Yep, I replaced a wrong coil. Changed it today and now all good. Thx
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
