those of you running 19" rims what tire size?
Old Dec 27, 2004 | 02:59 AM
mistermax's Avatar
i know this has been beaten to death but i can't find the old posts. i was just curious to know what tire size you guzy are running on the 19" wheels. i was thinking maybe a 235/35/19 or a 245/35/19. which is the better size? i was not able to find any tires with a 235/40/19 size. i was leaning more toward the 235 simply because i do not want rubbing issues and i also live in NJ. any clearance issues with a 2" drop on the 40 series tires?
Old Dec 27, 2004 | 03:02 AM
SEmy2K2go's Avatar
Go BUCKS!!!
245/35/19 - no rubbing at all. Many others run this size without issues as well.
Old Dec 27, 2004 | 08:18 AM
turbo_gg's Avatar
I've got 19"x8" rims, and I'm running 245/35-19's. Perfect fit, no rubbing. Just make sure your rims have the right offset, and you'll be OK.
Old Dec 27, 2004 | 08:30 AM
BP2K2Max's Avatar
i have 235/35's. so far so good.
Old Dec 27, 2004 | 09:30 AM
TEEdotMAX's Avatar
245/35 on 19x8 no rubbing
Old Dec 27, 2004 | 10:31 AM
silvermax2k2's Avatar
i have rubbing on my 17's.
Old Dec 27, 2004 | 10:39 AM
Jeff92se's Avatar
I'm needing a caw
Depends on the wheel width but here are some examples. Courtesy of the sticky in the tire/wheel section.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/50-17 4.4in 12.9in 25.9in 81.2in 780 0.0%
235/40-19 3.7in 13.2in 26.4in 82.9in 764 2.1%
245/45-19 4.3in 13.8in 27.7in 87.0in 729 7.0%
235/35-19 3.2in 12.7in 25.5in 80.0in 792 -1.5%
245/35-19 3.4in 12.9in 25.8in 80.9in 783 -0.4%
Old Dec 27, 2004 | 10:43 AM
maximamaybe's Avatar
I have 245/35/19 on 19x8.5 rims. The offset is +35.
Old Dec 27, 2004 | 11:10 AM
stevay's Avatar
245/35/19's for me.
Old Dec 27, 2004 | 11:51 AM
2000 Maximus's Avatar
Can i run 245/40/18 on my max
I know this is a tire question but it has to do with my 5th gen so i decided to put it here too.
So will 245/40/18 tires rub on my wheel wells when i turn or give me any problems? does anyone have this size on their car??
ANy comments would be appr.
PM or email as well - morovasa@shu.edu
Old Dec 27, 2004 | 12:34 PM
PearlWhtMaX2000's Avatar
245/40/19's here, but id say go with 245/35/19.
Old Dec 27, 2004 | 12:45 PM
Nathan's Avatar
Yeah what he said...
I have 245/40/19's but the correct size is 245/35/19
I'd recommend getting a 35mm offset, anything higher wont look very good.
Old Dec 27, 2004 | 01:07 PM
03tgtmaxima's Avatar
my duddy has a set of 234/35/19's on his truck and as nice as they look the ride is crap and handeling is trickey. however my boy has 245/45/19 on his ride and the seem to want to flex a little more while cornering keeping the car more stable when in a turn. and make sure that you are always on the pot hole patrol. my boy just his one in his truck and he bent the inside of the rim it was a 2 1/2 inch lip on the freeway where the pavement transitioned $150 for the fix or 800 for a new rim. gl
Old Dec 27, 2004 | 01:13 PM
mistermax's Avatar
i was thinking about buying myself these wheels in 19" size. what do you guys think? would the look better in chrome or silver finish on my 2k2 sterling mist? http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old Dec 27, 2004 | 02:14 PM
those look ok, but id def get them in a silver finish.
Old Dec 27, 2004 | 03:48 PM
ZIPPIN's Avatar
Mauja He Mauja
nice sig man. looks much better than the other one
Old Dec 27, 2004 | 04:14 PM
ucdaznboy96's Avatar
So it looks like 245/35-19 is the popular choice here. Based on the above table, it looks like the circumference/diameter is the same, so it fills the wheel well exactly the same amount as our stock tires and rims? I thought we'd want bigger and thicker tires to fill up the wheel well more.
Thanx alot
Old Dec 27, 2004 | 05:03 PM
mistermax's Avatar
ok guys. i just called the place that sells them and they said that one of the adr warehouses closed down so they got overstock on the chrome finish wheels, thats why they are running a special on them at a price of $679 for all 4. however, if i wanted them in the silver finish, they are going to run $400 EXTRA!!! do u really think its worth it? personally i thought that the silver finish would be easier to take care of but now im not sure if it would really be worth it to dish out the extra cash for silver wheels when the chromes are usually more expensive. wat do u guyz think? thanks again for all the input!
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
maximaham
Aug 20, 2015 10:23 AM
twotonezed
Aug 16, 2015 11:41 AM
