ARGH! $@#^&!# - Car didn't start this morning!!
So I've been parking my 5th gen outside for a couple of weeks now, maybe 7 weeks, and it has been as cold as 37 (or so my thermometer says) here in Cali a few days, but usually in the 40s in the morning.
Today, it was 57 on the thermometer -- much warmer although it was raining, but when I when to start my car (6 speed manual btw), it just sounded really weak and would not turn over. It was for sure not the alarm starter kill. The headlights came on and did NOT dim one bit while starting, so I doubt seriously it is an electrical/battery issue...
I kept trying to start it and gave it some gas and finally it started up...
I'm thinking it could have been any of the following:
- starter
- air
- fuel
- plugs
- injectors
So, assuming it wasn't the starter, lack of air (I do have an intake though), or fuel, it leaves the plugs and injectors, right?
My car is just about to hit 24k miles, and is almost 2 years old (was brand new when I bought it).. It's an '03.
ANY IDEAS WHAT HAPPENED??
- starter
- air
- fuel
- plugs
- injectors
Have your battery tested, I doubt its your starter since the car is so new. Most of the time VQ starters go out around 100-140K miles, mine will be here tomorrow I hope. My battery is dying right now due to very cold winter we have here in the Chicago area- was in the single digits for the last 2 weeks ! My car cranks very slowly and sometimes the starter just stops, and hits again- so I know its both the starter and the battery. If it was just the batt, the starter would click and not turn over. Optima Yellow top is on its way too
i had the same problem like 5 days ago. i garaged my car for about 5 weeks, than when i came home from svhool for the break, it wouldnt start. so i had it jumped and it started right up, and is fine now. so i think its just a mix of it being so cold, and not started for a while.
Yeah, I hadn't started it for 48 hours, which is a first probably.. at least during cold weather it is..
Why my lights were on? Well, they come on by default when I start my car. It's not like I put them on.. I know it drains on the battery during start.. :|
I had this problem about two weeks ago. Turn the key and nothing, push down on the gas a few times and it would start. One week later it did it again except this time it took about 5 turns of the key to finally start. I took it to Autozone they checked the charging system and the battery and said everything looked fine. One week later it was dead again. So I got a new battery and have not had any problems since. I think you have a bad battery because the dealer told me that the factory installed battery is only good for 2 to 3 years.
Lakersallday24
06-16-2019 01:35 AM
MAXSE5SPD
08-23-2015 12:06 PM
MaximaDrvr
08-19-2015 08:20 PM
