Any One Have A Problem With Brakes??
Old Dec 29, 2004 | 08:38 AM
JoE'sMaX01's Avatar
I have a 01 Maxima, and the brakes are feeling like they go to close to the floor and like it doesn't stop on key like it should. The car stops but I'm not sure if the brake pedal should go so low before it actually stops the car..
I wanted to know if any one else has experince this problem, could it be that my rotor or pads are no good? Or maybe my master cylinder is no good and needs to be replaced?
I have driven may different cars but I'm not sure about this car if anyone can help me in my situation I appreciate it
Thanks Happy New Year!!!!!
Old Dec 29, 2004 | 08:42 AM
Cutler's Avatar
sounds like a Bad MC or air in the system....
Old Dec 29, 2004 | 09:24 AM
JoE'sMaX01's Avatar
yea i was think the same thing but im not sure, just got the car and it drives great and it stops the abs work the whole nine but im not sure if the pedal is supposed to be that way. thanks I'll just have to change the mc.
Old Dec 29, 2004 | 10:29 AM
JoE'sMaX01's Avatar
Originally Posted by TopElement
MC's don't usually go bad. Thoroughly bleed the system and put in fresh, high quality fluid.
they dont??? i fig it would go bad at some point i no its only a 01 but i has close to 90k on it. I had a lhs and the MC went on about 150k so I wasn't sure wat the problem wit the max is. I didn't no if the pedal was supposed to go low before it actually stop cuz it seems to be close to the floor when it stop fully.
Old Dec 29, 2004 | 10:30 AM
Progress's Avatar
It's business time.
Before you do any of that consider how many miles are on the pads and rotors. Check to see how much life is on them and on the rotors and consider getting them replaced/turned. If you don't hear any squeeling then it might not be the pads. If your rotors are really glossy it might be them.
GL
Old Dec 29, 2004 | 10:47 AM
JoE'sMaX01's Avatar
no the pads are acutally pretty new and the rotors i think are okay im not too sure I haven't check those yet but I will prob tomorrow, too much snow and too cold for that rite now. But no noise like i said drives great but just the brake pedal seems to go too low for any car i've ever driven. You how u get in a car and at first you drive a car and press on the brake it stop instantly. well i press on the brake and nothin, press harder slows down you press it almost to the floor and it stops. again it stops no problem just the pedal seems to be low.
Old Dec 30, 2004 | 10:47 AM
murjose's Avatar
Seems more like a fluid problem. Make sure you don't have a leak.
Old Dec 30, 2004 | 11:03 AM
JoE'sMaX01's Avatar
nah no leaks, I check the fluid every day, hasn't moved from the line and the funny thing is that the fluid looks clean! and I'm just confused I'm goin to take the wheels off this weeked and check the rotors and pads.
Thanks again & Happy New Year!
Old Dec 30, 2004 | 11:41 AM
GBAUER's Avatar
Can't be the pads or the rotors (anyone who says differntly doesn't know how the system works). The brakes are self-adjusting, so check the fluid level. If good, then you need to bleed the breaks. Gotta do mine this spring as well.
Old Dec 30, 2004 | 11:48 AM
JoE'sMaX01's Avatar
Like i said I'm confused, I didn't know what do anymore. I no my pads and rotors are good I just saw them like a month ago when I rotated my tires. so I was just goin to check the MC and then if nothing worked bleed them out and re fluid them to c wat happens
thanks
Old Dec 30, 2004 | 12:13 PM
purekoryo's Avatar
I have a 2000 maxima with 62k miles. I've recently had the brake pedal go ALL the way down to the floor with no brakes at all and found out to be the MC. I've replaced it and added new and better brake fluid. Now it seems to be find, but the pedal still goes down a lil more than it should. Most likely there is still air in the line since i was in a rush to replace the MC and bleed the air out TOO quickly.
So, I would:
1. bleed the lines.
2. If 1. does not work, replace your MC.
Old Dec 30, 2004 | 12:31 PM
JoE'sMaX01's Avatar
So, I would:
1. bleed the lines.
yea looks like thats the best thing to do first, thanks purekoryo. I'm goin to try that first thing next year! thanks again
Old Dec 30, 2004 | 12:33 PM
JoE'sMaX01's Avatar
oh and GBAUER thanks. Your good you, your good! (lol steel alittle from analize this/that)
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
slowlifer
Sep 8, 2015 05:53 AM
