Axle ratio in '03?
Old Dec 29, 2004 | 03:22 PM
RobWilson's Avatar
Axle ratio in '03?
What is the axle ratio for an '03 auto versus an '03 6 spd? I'm thinking this may be the reason the percentage differences are so close on the dyno. For an '05 auto it is 2.44:1, for an '05 6 spd, it is 4.13:1. Are these numbers similar for an '03?
Old Dec 29, 2004 | 04:08 PM
03BlkSETE's Avatar
Gear Ratios 4sp A/T
1st 2.785
2nd 1.545
3rd 1.000
4th 0.694
Reverse 2.272
Final Drive 3.789
Old Dec 29, 2004 | 04:18 PM
RobWilson's Avatar
Thanks! I guess because of the extra gear in the 6th gen, the gearing is a lot different. Do you know the numbers for the 6 speed?
Originally Posted by 03BlkSETE
Gear Ratios 4sp A/T
1st 2.785
2nd 1.545
3rd 1.000
4th 0.694
Reverse 2.272
Final Drive 3.789
Old Dec 29, 2004 | 04:44 PM
03BlkSETE's Avatar
2002 6-speed ratios:
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th .809
6th .630
Rev. 3.002
F/D: 3.81
Old Dec 30, 2004 | 09:20 AM
RobWilson's Avatar
Thanks. That blows my dyno theory, then. Gear ratios effect your dyno numbers and I thought this might be why the percentage difference between autos and manuals were closer than in other cars I've seen.
When dynoing, the transmission is in the 1:1 gear ratio (3rd in the auto and 4th in the 6spd). The axle ratio can then skew the dyno numbers. The closer to 3.5:1, the better. If it numerically higher, it skews the dyno reading down and vice versa. For example, changing from a 3.42 gear ratio to a 4.10 gear ratio in a Corvette or Camaro, lowers your dyno reading by approximately 10 whp and 10 ft-lb.
Seeing that the axle ratio is so close on the A4 and M6, it must be the tranny losses are just closer than I'm used to.
1st 3.153
2nd 1.944
3rd 1.392
4th 1.055
5th .809
6th .630
Rev. 3.002
F/D: 3.81
boomerbrian
Oct 31, 2018 10:25 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
followthadollar
Sep 17, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
