Service Engine Soon
Old Apr 23, 2001 | 06:02 AM
maxedout1
Hey guys for some strange reason my Service Engine Soon came on this past weekend. What should I do or check. I am thinking about taking it to the dealer.
Old Apr 23, 2001 | 06:19 AM
UMD_MaxSE's Avatar
Got Bent?
hmm....since you have a stillen intake, make sure the sensors are all plugged in correctly. If it does not go out, I would take off your intake and take it into the dealer. They may give you trouble about it.
Old Apr 23, 2001 | 06:30 AM
maxedout1
oh no i havent installed the intake yet i just got it.
I have about 19500 miles on the car i know the 20000 service is coming up soon, maybe that may have something to do with it.
I am gonna call the dealer tho to see what they say.
I read in the manual that it may be an emission problem. Soo i cheked to see if the gas tank was on properly.
Old Apr 23, 2001 | 06:33 AM
UMD_MaxSE's Avatar
Got Bent?
ohhh...then just take it in to the dealer....
Old Apr 23, 2001 | 08:47 AM
jashick's Avatar
Same thing happened to me.
I took mine in and they replaced the cat converter... said it was malfunctioning.
Now I'm told that the program is prone to generate error codes of a cat converter malfuction when it's working fine. In this case, they'll do a simple computer program update.
In either case, take it to the dealer.
Old Apr 23, 2001 | 10:00 AM
maxedout1
Jashick thanks. Yea I called and they said they would put it on the computer. Did they charge you for the new part?
Old Apr 23, 2001 | 10:13 AM
djmaxski's Avatar
A malfunctioning cat? Why not just remove it all together....
Old Apr 23, 2001 | 10:16 AM
UMD_MaxSE's Avatar
Got Bent?
that should be covered under waranty....they can't charge you for that...
Old Apr 23, 2001 | 01:05 PM
jashick's Avatar
He'll need a functioning one to pass smog later on... no?
Old Apr 24, 2001 | 02:53 AM
Walt2KSE's Avatar
Bad Sensors
My service engine light came on in my 99 SE-L. After calling the dealer, they said to check to make sure the gas cap is tight. If air gets in the tank, this could be the problem. After the light stayed on, I took it to the dealer and it was a bad O2 Sensor. I have had two replace since in almost two years. Good Luck. Stefnee
Old Apr 24, 2001 | 06:59 PM
vasthana
Same Problem...
I have noticed the same problem...
However, it started after I went to a gas station to get gas. Used the CLIP to hold the gas flow at full, some reason, the gas overflowed, and ever since I have been getting the STEADY - Service Engine Soon light...
I read the manual, and it says, it is because of problem with the exhaust or just that the Fuel Cap is not closed properly...
Don't know.. I will wait for couple of days, and then I will take it to a Dealer...
Anyone had similar experience... Please HELP !!
Old Apr 24, 2001 | 07:39 PM
mdeal's Avatar
Walt2KSE,
Are those AE wheels you have? They look shiny. Are they chromed?
Old Apr 24, 2001 | 07:56 PM
Walt2KSE's Avatar
Yes...
Originally posted by mdeal
Walt2KSE,
I did a chrome swap with a shop here in Maryland. The owner said that people with 99's and older are getting the 2K SE wheels, He claims mine was the first 2K Max.
Stefnee :-)
Old Apr 24, 2001 | 08:14 PM
LoveSick's Avatar
My car was totally perfect; extremely smooth! But I still told my dealer that my car had slippage, misfire, and idle too low. They gave me the car back with tons of extra power.
Old Apr 24, 2001 | 08:33 PM
Green 2kSE's Avatar
You mean they flushed the ECU with the secret program to release the extra 10% hp? Good for you!
Old Apr 25, 2001 | 08:59 AM
yuryc
The "service engine soon" light came on last Thursday on my 2k Maxima GXE with just over 30k miles. Opened a hood, replaced air filter, added some coolant. Light is still on. Made an appointment with Nissan service for next Wednesday (today). This morning started the car to go to service and the light is gone. Went to Nissan anyway. They told me that they'll charge me for reading the codes because there was no light. I just left. Next time I'll try to get it into service sooner.
YuryC
Old Apr 25, 2001 | 09:17 AM
punkdork's Avatar
YuryC
Gotta love that.. charge you to read the codes... how about you give me a way to decode them? What a crock.
Old Apr 25, 2001 | 12:21 PM
NYC2SD's Avatar
FIRST AND FOREMOST!!!
Make sure the gas cap is on tight. That will trigger the light!!
Old Apr 25, 2001 | 12:49 PM
bry2kse's Avatar
ECU Re-program...
Here's my story.. Service Engine Soon light came on for no particular reason last month. Solid light.. meaning emissions problems.
I brought the car to the dealer and the ECU spit out a "bad cat" code..
Well.. some dealers would just replace the cat and send you on your way..
The problem is a misdiag of the emissions system by the ECU on some 2K Maxima's. The fix? A simple ECU update.
I had my ECU reprogrammed and the car hasn't thrown a code since. The throttle also responds much better (5 speed) and the gas milage may even be a bit better (though this could be the placebo affect).
Ask your dealer to check for a ECU TSB.. and for anyone driving a 5 speed... the throttle is so much smoother at very low and very high (4000+) RPM.
- Bryan
Old Apr 25, 2001 | 01:04 PM
jashick's Avatar
Originally posted by bry2kse
ECU Re-program...
- Bryan
I posted the same thing a few months ago.
But in my case, they replaced the cat converter cuz
it happened before they figured out anything about the
ecu misdiagnosis...
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
