SE Stalling when coming off high revs
Howdy all,
My wife's 2000 Maxima SE occasionally stalls when coming down from high revs. I notice that even when it doesn't stall, the tach shows the engine dropping below 500 RPM and then quickly raising again to ~ 800 - 1K RPM.
The dealer has no clue of what's happening.
Suggestions???
Peter in Plaistow
Suggestions???
Peter in Plaistow
Originally Posted by PBealo
Howdy all,
Suggestions???
Peter in Plaistow
Suggestions???
Peter in Plaistow
I posted this in another thread:
Originally Posted by amstrad
Same thing happened to me (2K 5-spd, 68,000). It idles lower than normal and when applying brakes (which drains a little power) with clutch depressed, the RPM drops below stall point. First time that I've had a legitimate reason to start the engine with a clutch pop.
Then I noticed it only happens with the A/C off (I use the A/C most of the time here in Florida). I just figured that my ECU needed to be reprogrammed. My solution -- turn A/C back on. Hasn't stalled since.
It's not a TB issue or anything, just a plain old low idle condition. I had this exact same problem a couple of years ago. Driving down a highway, doing 70-80-90 in 5th, clutch in, neutral, clutch out, 1-2 seconds later stall. This happened more often when I was doing 70-80-90 in 4th or 3rd and dropped to neutral.
At one point I went to the dealer and I noticed that my idle was a bit high, 750 vs. 600. Since that point I have never had a problem. Bounce off the rev-limiter in 3rd (mucho-fun!) in to neutral, no stall, never, never ever seen it.
I think it was a simple idle adjustment and not an ECU flash. I have always had, and still to this day have, the infamous cold engine - 1600 RPM blip (choke, chug, skip...)
Originally Posted by Stardust
Yea low idle caused by a dirty TB.
and couldnt thins be caused my a MAF on its way out? not fully gone baut bad? mine does the same but i can rev above 2500 rpms.
Originally Posted by super6
oh absolutly, i meant that he said that his idle was high (800)
What do your RPM's peak at when you start your car? Do you consider that a high idle problem? When you car is about to die it corrects itself by giving it a little more gas making it jump to 800-1000 before settling back down to normal ~650 RPM idle.
[QUOTE=bert]At one point I went to the dealer and I noticed that my idle was a bit high, 750 vs. 600. Since that point I have never had a problem. Bounce off the rev-limiter in 3rd (mucho-fun!) in to neutral, no stall, never, never ever seen it.QUOTE]
you see?????????? he said it was high!!!!!!!!!!!!!!!!!!!!!!
[QUOTE=super6]
I was talking about the thread starter, and thought he was also. honest misunderstanding.
Ok, this is what happened....
The idle was low (600).
I was having the problem.
Went to the dealer for something or other, not this problem. (Fuel level sender I think, or sunroof motor)
Noticed that my idle was now higher (700-750).
Figure the dealer either flashed the ECU or more likely just did an idle adjustment.
Never had the problem since.
Clear now?
Clear now?
Clear now?
Clear now?
SmokinMax02
18
Sep 11, 2015 12:25 AM
BobMax
Aug 15, 2015 12:35 PM
MikesChevelle
Aug 6, 2015 11:36 AM
