programing keyless entry
Old Jan 3, 2005 | 02:14 AM
MAX 2NR's Avatar
does anybody know how or where i can find instructions on how to program a keyless entry remote for an 02 max?
Old Jan 3, 2005 | 05:55 AM
dreadsilk's Avatar
programming instructions
inmportant :have all all transmitters for your car in your possession.once you program the transmitter it will erase all the previous codes from memory.u must all transmitter at the same time.
1.close and lock doors with the driver's side power lock/unlock switch.
2.insert the key and remove it from the ignition key cylinder completely at least 6 times within 10 seconds.if this this procedure is performed too fast,system will not enter progrmming mode.your hazard lamps will flash if you have performed this step succesfully.
3.insert key into ignition cylinder and turn to the acc position.
4.within 5 seconds,push any key on the remote transmitter. do not push the button more than one time.programming will not work.hazard lamps should flash.
5.if u have any more transmitters(including the old ones),unlock then lockall doors using the driver's side lock/unlock switch and within 5 seconds,push any button on the next remote.your hazard lamps should flash.repeat this step for each transmitter(including any existing transmitters).
6.turn the key to the off position,remove keys from the ignition,nulock doors using the driver's side power lock/unlock switch and open driver side door.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
