Cattman Headers question?
Old Jan 3, 2005 | 08:38 AM
Deltron's Avatar
Just got my cattman headers system in and will be installing this weekend.
was wondering if there is anything i should know about before i go through with this.
certain tools, known problems, etc...
comments would be greatly appreciated.
Old Jan 3, 2005 | 08:44 AM
claudiusmaximas's Avatar
don't headers require professional installation? unless you are a mechanic then nevermind
Old Jan 3, 2005 | 08:45 AM
hey how much was your headers and did it come with the y-pipe? where did u get it from?
Old Jan 3, 2005 | 09:04 AM
Deltron's Avatar
headers were $850 after shipping gaskets and manual. yes the headers come with a y-pipe
www.cattman.com but there website sucks you have to order over the phone
the number is on the site under 'contact us'
Please i am looking for good comments/suggestions here to my original question.
Old Jan 3, 2005 | 09:07 AM
NmexMAX's Avatar
dot dot dot ...
It doesn't require rocket science, just time/patience. Depends on your take on what a mechanic is.
It's just a matter of getting them from the bottom. You shouldn't have to remove the IM. Access to a lift is greatly appreciated.
Pretty simple, Crossmember, 2 engine mounts. 2k2/3 do not have EGR port, so it must be plugged, loosen/remove AC compressor, relocation of the 2 O2 sensors (no the ones in the old manifolds, but rahter the 2 that are on the stock y-pipe.) to the B-pipe.
Cattman brad new are ~$825 new and they come with a y-pipe/headers combo but cannot be used in conjunction with any other brand y-pipe, at least not to my knowledge.
Old Jan 3, 2005 | 09:08 AM
NoMotive's Avatar
Brian at cattman had mentioned that it would be a good idea to wrap your motor mount with some sort of reflective wrap as the header sits quite close to one of the mounts.
Old Jan 3, 2005 | 10:02 AM
NmexMAX's Avatar
dot dot dot ...
One of the pipes is also real close to the oil pan and a rubber hose in that area, might be a good idea to check on that small hose from time to time, and perhaps wrap it also.
Old Jan 3, 2005 | 11:47 AM
Deltron's Avatar
thanks for all the info, also how long did it take you guys to install these how many hours?
Old Jan 3, 2005 | 12:02 PM
NmexMAX's Avatar
dot dot dot ...
Set aside a couple of afternoons.
Old Jan 3, 2005 | 02:02 PM
frankieduxAE's Avatar
the hardest part for me was getting the heatshield off on the rear manifold and the rear engine mount bracket. Be sure to get some woble adapters. Ratchet wrenches are also a big plus, it'll save you alot of time and they get to hard to reach spots.
With two people it took about 10 hours to install both cattman headers and exhaust.
good luck!
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
