could my MAF be going out?
Old Jan 4, 2005 | 08:35 PM
super6's Avatar
when i shift to neutral the car dies while criusing sometimes, or it drops the rpms real low, then i have to rev it to keep it from stalling. drives kinda wierd also. so ses no codes.
could the maf be partially dead? or if its the MAF a code would come up? MAF looks fine. could it be a dirty TB causing the problem or something else, any and all input appriciated.
Old Jan 5, 2005 | 09:52 AM
DJSCIASCIA's Avatar
I remembered that same thing happend to me once and it was the result of a slight opening i had between the maf and the TB. My clamps on the intake came loose. I put that sucker together and all was better.
Old Jan 5, 2005 | 10:03 AM
nickk817's Avatar
Hi, I have quick question as well, about my MAF. Ok, my car isn't running very well when I start my car up sometimes it stalls unless I hit the gas pedal. Also my car hasn't been running as quick as it should be or maybe that's how quick it is, because I lost in a race to a denali. SO I think im lacking my performance due to my MAF, after hearing other complaints that sound somewhat familiar. If it is my MAF and I wanted to clean it where is the MAF thanks you all for your time. because I shouldnt have lost to a denali I got a cattman y-pipe injen intake and a greddy evo cat-back.
Old Jan 5, 2005 | 10:06 AM
adithius's Avatar
Some previous posts mentioned that the coolant temperature sensor might be the culprit. It's a $27 part and it's easy to change.
Old Jan 5, 2005 | 10:12 AM
super6's Avatar
can you help out and show mw where you seen that, thanx.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
