Betcha can't solve this lighting mystery!
Old Jan 5, 2005 | 09:06 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Ok, here's the deal. My passenger-side rear brakelight is malfunctioning. Specifically, here's what's wrong:
LIGHTS OFF, TURN SIGNAL ON
-The front turn signal DOES flash
-The rear turn signal DOES NOT flash
-The clicker goes 'click-click-click' on the inside
-The instrument cluster arrow does not light
LIGHTS ON, TURN SIGNAL ON
-The front turn signal DOES NOT flash
-The front turn signal lights up
-The clicker DOES NOT go 'click-click-click' on the inside
-The instrument cluster arrow DOES NOT light
Kudos to the genius that solves this one!!!!
Old Jan 5, 2005 | 09:10 AM
NmexMAX's Avatar
dot dot dot ...
Rear tail blinker os out. It's all resistance and the process of the relay reacting to the dead blinker.
Old Jan 5, 2005 | 09:18 AM
How would I fix this bugger of a problem, then?
Old Jan 5, 2005 | 09:21 AM
NmexMAX's Avatar
dot dot dot ...
Just buy a new tail blinker, check the car manual for the light part # or at some stores they have a reference catalog with part#'s, math the year/make/model and find it, pop the trunk lining, snap out the bulb, replace with new one, snap back into place, put trunk lining back together.
One way to check it the blinker is indeed out, flash the hazards and stand behind the vehicle to verify it's not working.
Old Jan 5, 2005 | 10:33 AM
Yeah, I have tried the hazards, no luck there. I ahev also tried another bulb. So all I need is to get a new blinker unit?
Old Jan 5, 2005 | 10:41 AM
ZeRo MaX's Avatar
A NEW REAR blinker might do the trick...
Old Jan 6, 2005 | 03:58 AM
Alright, I hate to sound like a complete dumba$$, but where would the rear blink module be, and how would I replace it?
Old Jan 6, 2005 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
Just change the bulb.
Old Jan 6, 2005 | 06:22 AM
I did! The same probelm still exists...
Old Jan 6, 2005 | 06:40 AM
speye022's Avatar
Could it be the relay for the turn signal? I think it goes one for the driver side and one for the passenger side. Open your hood, look in the black box on the left. The relay you need should be labeled on the underside of the cover. Actually just to make sure, switch the relay from your driver side to your passenger side. Check to see if the passenger side turn signal work. If it does, then you know what to replace.....right?
Old Jan 6, 2005 | 07:25 AM
kcowden's Avatar
If not the bulb then the relay most likely. If you need a diagaram let me know.
Old Jan 6, 2005 | 07:29 AM
ghostrider17's Avatar
Simplist & most time effective....just did this on my motorcycle, so to speak.
Swap parts to test for dead relays/bulbs.
Go get 'em sparky.
gr
Old Jan 6, 2005 | 10:05 AM
Go get 'em sparky.
gr
I will test this when I am done work today...just so I am prepared, how would I go about changing a dead relay?
Old Jan 6, 2005 | 10:53 AM
speye022's Avatar
take out old relay (it pulls out kinda like a fuse), plug in the new one. I think they sell relays at NAPA, Autozone, Pepboys and such.
Old Jan 6, 2005 | 04:09 PM
Ugh, finally found it. I did a bulb swap-out on my cluster a week ago, and the turn signal bulb came loose...that was it!
I wish I checked this before I took a ******* multimeter to all the relays
I would like to say, though...thanks to all those whom have provided their insight to this problem, you make this site worthing coming back to again and again!
fastcarny
Oct 6, 2015 10:42 AM
97_GXE
20
Sep 17, 2015 08:12 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
