weird smell
Old Jan 5, 2005 | 07:22 PM
merovi's Avatar
weird smell
Ok, i was driving on the expressway..and i really wasn't going that fast..maybe 75 or 80 and everything was normal...then when i got off all i could smell was a terrible egg smell almost. I have read that that smell is a problem with the cat. But the weird thing is when iw as driving back i wasn't on the expressway and was doing about 60 and i never smelled a thing. Then later ont he expressway doing about the same speed i didn't smell anything. Neither of these times did i drive more differently then the other i wasn't really reving or pushing the engine. I dont know if it makes a diff but i also only smelled it when i got off and not when i was driving. After i got off i could smell it as i was driving though. Plesae help.
Old Jan 5, 2005 | 07:36 PM
dkotanto's Avatar
I hear they have changed some gas formulation to include more sulfites. This could explain it...
Old Jan 5, 2005 | 10:01 PM
Ghase's Avatar
It's your catalytic converter. That's why you smell eggs. And hopefully you wasn't on a date like I was when it happend to me..LOL You can also check by looking under the car to see if you have a string hanging from the CAT, if so your cat is your cat is in bad shape. It's sound crazy, but it accurately works.!!!!!
Old Jan 5, 2005 | 10:21 PM
Matt_01SE_20th's Avatar
since it just happened that once. it could have been just some foul smell in the area due to a factory or a landfill. i get that alot when driving to the airport near the factories and sewage treatment plants but also have noticed it spottily other places. could have been from a car ahead of you too. i wouldnt start looking at a bad cat until it is more consistant.
Old Jan 6, 2005 | 09:26 AM
PrinzII's Avatar
OG and counting...
Nine times out of ten, it's the catalytic converter.
Old Jan 6, 2005 | 12:06 PM
merovi's Avatar
i have smelled it before..but only when i was driving it very hard and practically red lining in 1,2,3rd gear. and it usually goes away pretty fast. Maybe it was the sewage because i haven't smelled it again since and i have been doing both expressway driving and regualr driving. I hope its not that cat. if it is are they expensive to replace?
Old Jan 6, 2005 | 12:13 PM
Cutler's Avatar
Sounds like Cat.... Covered to 80k under emissions warranty...
Old Jan 6, 2005 | 12:18 PM
GreenSeMax's Avatar
it's usually the cat, i'd try switching fuel brands first, but if it persists, it's def. the cat
Old Jan 6, 2005 | 12:27 PM
merovi's Avatar
i have 116k on my car
Old Jan 6, 2005 | 01:23 PM
Arek's Avatar
When you rev your car you computer send a signal to give more fuel and sametimes it is to rich produsing that smell. Almoust all cars do that same more some less.
Old Jan 6, 2005 | 02:18 PM
OutMaxxed's Avatar
so thats what that string is under my car. No wonder it smells, i always thought it just stunk around my house. What does that hanging string mean. What is that string?
Old Jan 6, 2005 | 02:39 PM
SoonerFan's Avatar
Cletus
then explain why a car with no cat doesnt make that smell??
Old Jan 6, 2005 | 02:45 PM
Max20SE00's Avatar
That string is just a ground for the catalytic converter. Dealer told me that it really doesnt do anything and not to worry about it. Mines hanging and have no smell and cat is working fine.
Old Jan 6, 2005 | 02:51 PM
CCS2k1Max's Avatar
This is what my neighbor, who's a Porsche mechanic, told me. It's a "left over" from the days when first generation O2 sensors were one wire and needed to be grounded and it's not really needed. The "string" is just a grounding wire (if you look at it it's braided). After he explained this, I cut mine off after it came lose from the exhaust pipe. This was about a year ago and nothing bad has happened.
As for the smell, if it's not the Citgo gasoline you've been using (fairly high sulphur), it's the cat as everyone else has said.
Old Jan 6, 2005 | 02:54 PM
Cutler's Avatar
Signs of a failing cat is the rotten egg smell, hence no cat gives you the smell.....Think before you post next time
Old Jan 6, 2005 | 02:56 PM
SoonerFan's Avatar
Cletus
and im saying that a "friend" removed his cat and there was no smell. you know that...you helped him remove it
Old Jan 6, 2005 | 02:57 PM
Cutler's Avatar
There is strong smell from Your car, sorry. But now that I think of it, I believe the smell is more related to the internals of the cat burning off, I stand corrected sorta......
Old Jan 6, 2005 | 03:06 PM
SoonerFan's Avatar
Cletus
there is no smell...its the same as before the cat was removed
Old Jan 6, 2005 | 04:51 PM
2000 Maximus's Avatar
As many have said above - CHANGE YOUR CAT - and the smell will go away.
Old Jan 6, 2005 | 04:56 PM
Gooey's Avatar
i have a test pipe and i rarely get that smell maybe once in a blue moon when i have ppl in the car
Old Jan 6, 2005 | 05:14 PM
SoonerFan's Avatar
Cletus
exactly!!
i think its a "your cat is going bad" smell. its not the smell of the exhaust that isnt getting cleaned since the cat is bad. if that was the case we would get that smell
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
RWCreative
Sep 21, 2015 11:01 AM
carid
Sep 17, 2015 05:00 AM
bennuss
Sep 11, 2015 05:55 AM
