I need help fixing my rear-defoggers.
Old Jan 6, 2005 | 05:46 PM
snair2's Avatar
Hey, earlier today, I was hooking up a cd changer, and decided to check out the antenna thing located in the rear-right pillar, so I popped off the interior panel at that pillar and suddenly, little specks of glass was falling. Apparently the rear windshield was replaced for some reason.
The actual problem is that, the person that put the new windshield did not reattach the rear-defoggers to the glass, instead they just left it hanging inside the pillar. I noticed before that the rear defoggers never worked, but figured it was a fuse or something electrical.
How would I go about fixing this problem?
Old Jan 6, 2005 | 05:58 PM
I30swimmer's Avatar
reconnect the wires?
Old Jan 6, 2005 | 06:05 PM
snair2's Avatar
I didn't really take the time to even concentrate on the rear-defoggers, since I was tied up with setting up the cd changer. Normally, all that is required is to plug the thing into something? The thingy thats hanging (that should be attached the window), is like a 1/3 the height of a pinky, rectangular shaped, and is attached to a wire. It looks like it should be attached to the window.
So it just plugs in, or am I supposed to glue it onto the window?
Old Jan 6, 2005 | 09:05 PM
snair2's Avatar
bump.
u
m
p
Old Jan 7, 2005 | 10:14 AM
snair2's Avatar
Once again, another bump, if its an easy fix, I just need to know what to get.
Old Jan 9, 2005 | 02:22 AM
aussie983's Avatar
Uh soldering iron? Solder them back on?? not sure how it connects cuz ive never seen the inside of the pillar.
Old Jan 9, 2005 | 06:12 AM
njmaxseltd's Avatar
There should be a pig tail lead coming off the rear window that the plug you found plugs into. There are two conntections, positive and negative. Make sure TWO plugs or a TWO wire lead is plugged into your rear window.
Old Jan 10, 2005 | 03:38 PM
supercat's Avatar
If its not stuck to the window its a pain in the a** I tried in my mustang and it came out
like s***. If you have a multimeter you can test for voltage, then fix the breaks, but if you want the job done right have a new one installed. Its a hard, delicate job with little working space for the 1st timer in this case.
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
