driverss door saging
Old Jan 7, 2005 | 12:38 AM
nexus_7's Avatar
easy fix?
Link or anything?
Greg
Old Jan 7, 2005 | 03:43 AM
jimmycapp's Avatar
i went to adjust the striker plate last weekend. I used an impact driver and i still stripped and couldnt get out one of the screws. BOO
Old Jan 7, 2005 | 06:14 AM
nexus_7's Avatar
ill put that in the maybe pile then.
Greg
Old Jan 7, 2005 | 11:20 AM
GreenSeMax's Avatar
i put shims in the lower hinge to adjust it. If you move the striker you're merely allowing the door to hang improperly, but it will close nicely. If you shim it, like traditionally body panels are aligned, then it should line up.......I am just curious as to what would cause this.
Old Jan 7, 2005 | 11:42 AM
jimmycapp's Avatar
good thinking
Old Jan 7, 2005 | 01:26 PM
nexus_7's Avatar
find a shim....that sounds like another project. Ill be looking into that.
Greg
Old Jan 7, 2005 | 01:51 PM
Barc's Avatar
Mine doesn't sag, but the striker doesn't meet up properly (you can feel it "grab" a little when you close the door, not that most people would notice but I do). As I bought it used, I don't know what was done prior to me buying it but I can see an obvious repair on the upper hindge as it has an unpainted nut on the top bolt where the passenger side has both nuts painted. Maybe a shim would fix my small problem. And I'd have to say it was sagging before I bought it or else there would not have been a repair there. Who knows, though? Some people do crazy things to their cars!
Old Jan 7, 2005 | 01:53 PM
Cutler's Avatar
weight over time causes this, unless your hinges are going bad
Old Jan 7, 2005 | 02:19 PM
GreenSeMax's Avatar
yeah weight, i just meant i can't figure an exact incident that caused it
Old Jan 7, 2005 | 02:20 PM
Cutler's Avatar
I mean the weight of the door, causes the hinges to sag, replace those and shim if necessary
Old Jan 7, 2005 | 02:50 PM
irish44j's Avatar
retired moderator
Does that happen in Hondas too, Jason?
Old Jan 7, 2005 | 02:59 PM
Cutler's Avatar
Prolly so
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
