Po430
Old Jan 7, 2005 | 01:33 PM
dreadsilk's Avatar
Po430
i have 00 maxima gle and its spitting out a PO430 code bank 2.can anyone tell me what this code means?
Old Jan 7, 2005 | 01:41 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Well, technically it is:Catalyst system efficiency below threshold on Bank 2. Honestly you should change out your 02 sensors and clear the code, see if it comes up again - the dealer is going to give you a MASSIVE list as to what it COULD be...
Old Jan 7, 2005 | 01:53 PM
dreadsilk's Avatar
any idea how much to replace the o2 sensors
Old Jan 7, 2005 | 04:01 PM
MY2000MAX's Avatar
check the stickies for it.
Old Jan 7, 2005 | 04:49 PM
E55AMG2's Avatar
Wat
Its not cheap. Call Dave Burnette: 1888-254-6060, he has the best prices on OEM parts.
Old Jan 8, 2005 | 05:22 PM
killer924007's Avatar
i got the same problem before,i think probably is the bad cat..cus the sensor sen the cat is not doing it's job... i bought an oxygen simulator $30 dollars to slove the problem and just guts the cat.
Old Jan 8, 2005 | 05:50 PM
dreadsilk's Avatar
what is a oxygen simulator and where can i get it.how many o2 sensor does the max has.
Old Jan 8, 2005 | 06:19 PM
http://www.o2simulator.com
total 4 oxygen sensors if u have a california spec!! ur P0430 is the bank 2 pre-cat and the oxygen sensor got a red wire cover.
Old Jan 8, 2005 | 10:04 PM
nismo_star's Avatar
P0430 = replacement of pre cat front bank if P0420 reprogram done.
8yrs/80K mi Nissan Emission Components Warranty.
Old Jan 8, 2005 | 10:40 PM
S00NR1's Avatar
OU > *
Yes, this is covered by your 8/80 emissions warranty if you have a cali-spec. Check the TSB's and you will find out more.
Old Jan 9, 2005 | 12:23 PM
dreadsilk's Avatar
so the dealer should take care of it.i checked the o2 sensor and its has the cali specs.
David3267
Aug 21, 2017 08:27 AM
Trin1j23
May 7, 2015 04:28 PM
David3267
Jan 22, 2014 07:20 AM
jerseyboy83
32
Jul 21, 2011 08:43 PM
BLUEMAX01SE
May 9, 2005 03:54 PM
