O2 sensor question
rear (secondary) o2 should not affect gas mileage as its only function is to monitor the precats (cali spec) or precat and main cat (fed spec). if you have a bad primary o2 sensor then it will affect gas mileage as it is one of two configuring tools for your a/f ratio. you have a primary on each bank and one secondary if you fed and two primary and two secondaries if you are cali spec.
P0138, P0139 are part of a bulletin from NISSAN which its replacing both rear o2s and reprogramming of ECM.
Unless you had them done already, then your o2 harness may have a cut in it.
8yrs /80K mi
8yrs /80K mi
The service bulletin (NTB02-051a) only refers to rear O2 sensors. I had codes P0139 and P1147. http://maxima.theowensfamily.com/tsb...=2000&tsb=none
i have this issue at the moment, too. The nearest dealer is 70+ miles (of snowy roads) away. I recently had my MAF fail, and have been having a very high, 'bouncing' idle. I replaced it today, but it still have the same issue.
Could my rear o2 sensors be to blame for this bad idle? The only other thing I can think of is that my ECU needs to re-learn the fuel/air ratios.
(Sorry for butting in...)
from what I understand, the original ECU programming will trip P0138/9 SES codes when in fact the sensors are fine. I've heard that reprogramming will keep this from recurring, if your sensors are in fact ok. I plan to get this done some time, but the nearest place that could do it is 70+ miles of snowy, icy roads away
As for the MAF reprogram, I believe it's part of that same firmware update.
Good news...
I called my extended warranty company and the o2 sensor is indeed covered by them. I'm glad I did purchase this gold plan. I"m also getting my powerseat fix on driver seat that will not move forward or back. So, the extra money in the extended warranty is definity paying off now. I got 2yr9months left or 32,000mi more on it. wwwwooooohooooo.
sdotcarter
Sep 2, 2015 09:53 PM
