Exhaust Question....
Old Jan 10, 2005 | 07:22 AM
dadiesel's Avatar
This may be a dumb question, but i'll ask anyway. I currently have just the stillen downpipe and their exhaust, so do I still have a cat? Also, are their any other exhaust mods available besides headers, which i am oh-so close to ordering (B-Day=24th)? Thanks.
Old Jan 10, 2005 | 07:30 AM
NmexMAX's Avatar
dot dot dot ...
You still have a cat, you can check for yourself by looking under the car.
Headers are the only other option, which will require you to eliminate your current y-pipe.
Old Jan 10, 2005 | 07:46 AM
Puppetmaster's Avatar
What he said is right... I assume ya mean a Stillen y-pipe and rear section... so you should still have your stock cat and b-pipe. Just take a look under the car and the cat is the thing between your y-pipe and b-pipe....
Its SEC 208 from the diagram below...
Old Jan 10, 2005 | 05:56 PM
dadiesel's Avatar
So is it a good idea to get a high flow cat? and do they sell different B-pipes?
Old Jan 10, 2005 | 06:11 PM
Ammi's Avatar
350 Detroit Muscle
you can get 3" pipes but not really worth it unless you are boosting
Old Jan 10, 2005 | 07:15 PM
A high-flow cat won't really give ya that much gains... the stock cat isn't all that restrictive... as for b-pipes... if you're looking for 2.5" b-pipes... try Cattman, Budget, and Warpspeed....
Old Jan 10, 2005 | 08:02 PM
dadiesel's Avatar
So because I'm boosting, do i need the high flow cat?
Old Jan 10, 2005 | 08:10 PM
dadiesel's Avatar
Also, is the cattman b-pipe called a midpipe?
Old Jan 10, 2005 | 08:12 PM
Sorry, I don't know how the cat will affect the flow if you're boosting... intuition tells me that if ya need 3" exhaust piping, then you'll need a higher flow cat... try posting this question in the FI/TC/SC forums.... they might be able to help ya better there....
Old Jan 10, 2005 | 08:33 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
some companies will refer to the b pipe as a midpipe. just make sure you if are having a custom b pipe (mid pipe) that it goes the distance right before it bolts up to your stillen axel over. if you are boosting, id skip the high flow cat and just go for a test pipe. when/if you have emissions then put the stock cat back on.
Old Jan 10, 2005 | 08:46 PM
dadiesel's Avatar
So where do I get a test pipe at? or is is something that is custom made?
Old Jan 11, 2005 | 05:26 AM
sloppymax's Avatar
contact warpspeed, custommaxima, budget or have a local place look at making you one. by law they cannnot remove a working cat but its a very easy replacement. if you are boosting i would suggest the custommaxima just because it is 3 inch if i am not mistaken.
Old Jan 11, 2005 | 11:42 AM
dadiesel's Avatar
Are cattman headers 3 inch?
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
