Engine Dress up/Sound deadening
Old Jan 10, 2005 | 08:01 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Well I played around a bit with the VHT paint I bought for my calipers. Engine cover screws and battery tie down. I think the tie-down looks a bit cheesy in person.
Also, I finally got around to working on the rattles from my trunk.
Engine work
More pics toward the bottom
Sound deadening.
This helped a ton. I can't begin to tell you. I was sceptial at first, but I was really surprised when I tested it out. Also, the install looks good, nothing hanging out or anything like that. The plastic screws were pretty tight to get back in. But that liner is really solid now.
More pics toward the middle of the page
Old Jan 10, 2005 | 08:02 PM
joebangaa's Avatar
where's you put that foam???? rear deck or the trunk lid above?
Old Jan 10, 2005 | 08:04 PM
Epacy's Avatar
Wow, insanely quick response, lol. That is the trunk lid in the photo.
Old Jan 10, 2005 | 08:43 PM
joebangaa's Avatar
o wow didnt realize you posted it a minute earlier, so you took that carpeting off, put on the foam and put that liner back on?? its not too thick??
Old Jan 10, 2005 | 08:56 PM
LA02MAX's Avatar
how does that deaden the sound? does it just keep the trunk lid from rattling?
Old Jan 10, 2005 | 09:01 PM
Epacy's Avatar
No big. Yes I did exactly as you described. I took off the liner and used it to outline on the adhesive foam. Then I cut the foam to shape. It was very thick but with some elbow grease you can push down the liner over the foam and push in the plastic screws. They snap very snuggly into place.
Old Jan 10, 2005 | 09:02 PM
LA02MAX's Avatar
oic, thats pretty creative...did you have to have a pretty steady hand to be able to cut it perfectly? cuz i sure dont!
Old Jan 10, 2005 | 09:29 PM
Epacy's Avatar
The foam absorbs the sound and keeps it from hitting the trunk lid, mostly. It greatly reduces trunk rattling, which is a huge annoyance when listening to music. Also, I find it sh!tty to run around town with your trunk lid rattling like a mule.
Old Jan 10, 2005 | 09:34 PM
S00NR1's Avatar
OU > *
Ya, so maybe it won't sound like a ghetto ricer anymore!!
Old Jan 10, 2005 | 09:35 PM
Epacy's Avatar
Originally Posted by S00NR1
Ya, so maybe it won't sound like a ricer anymore!!
You're just jealous. And ricer it is far from!
Old Jan 10, 2005 | 10:26 PM
Epacy's Avatar
I used a ruler of sorts, a moderately long wooden piece of wood, for the long strecthes. Otherwise, you have to free-hand some stuff. It wasn't that bad. Just plan it out.
Old Jan 11, 2005 | 08:46 AM
bladerunr's Avatar
Nice mod. Where did you pick up the foam?
Old Jan 11, 2005 | 09:38 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Alot of deadeners are simply sheets of asphalt that serve to add additional weight to surfaces (i.e. - your trunk) and absorb noise. The heavier the item, the more resistant it becomes to movement due to vibration.
Old Jan 11, 2005 | 10:26 AM
Epacy's Avatar
The foam was from my dad's work, they were going to trash it so I picked it up along with some other sheets. It is an industrial adhesive foam. It is thick, but doesn't weigh hardly anything.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
