Another CAT Conv brand question.
Old Jan 11, 2005 | 08:52 AM
Sammzway's Avatar
Anyone used the high flow cat conv from Warpspeed? I'm planning on ordering one, any input? Thanks.
Old Jan 11, 2005 | 12:07 PM
makavelisk's Avatar
I order one for my old max and I have the same one on my current max and I have not had any problems with it yet. Warpspeed sux a$$, but their cats are not to bad. Ill give them that.
Old Jan 12, 2005 | 07:59 AM
RichP23's Avatar
Mine just went after about 8 months. I got it in the group deal with the Y-pipe. So now I'm looking for a new one.
Old Jan 12, 2005 | 08:29 AM
Sammzway's Avatar
Hmmm, interesting, what brand are u looking to get?
Old Jan 12, 2005 | 09:10 AM
RichP23's Avatar
Not sure. The one I got from Warpspeed in the GD was a Magnaflow Carsound cat. I don't really know much about them. I have a 2k cali spec. I was looking at the ones on e-bay, but they seem like basically straight test pipes.
Here's a link for some that are not direct fit and need to be welded on:
http://www.completeexhaust.com/magna...7296abfcd9f58a
Can someone point out which 2.5" cat would fit my 2k cali spec?
Old Jan 12, 2005 | 01:16 PM
SoonerFan's Avatar
Cletus
three-way catalytic converters on todays cars use a honeycomb structure. they are less restrictive then the older kind that used ceramic beads.
bottom line...the "hi-flow" cats are not much less restrictive then the stock one so i feel that they are a waste of money.
Old Jan 12, 2005 | 01:45 PM
RichP23's Avatar
Would you do me a favor and help me pick out the correct cat for my car?
I have no f'n idea what I need with my cali spec. I don't car if it's direct fit... I'll just have the shop weld it on. I just don't know how many ports, etc...
Old Jan 12, 2005 | 01:58 PM
E55AMG2's Avatar
Wat
I have the WSP metal substrate cat, it flows MUCH better than the OEM 5th gen cat......when you have a full exhaust setup. This is the only time a high flow unit is worth it, otherwise dont waste the $$. Reliability, Ive had it on for 30k miles and its doing just fine
Old Jan 12, 2005 | 05:05 PM
mdloops's Avatar
E55AMG2 - GOT any proof it flows "MUCH" better? Didn't think so. Post a dyno before making claims contradicting 90% of the maxima population
If you buy warpspeed performance don't expect ANY warranty. From the second you get your parts you are on your own. If you buy anything from Dallas you are ASKING to be f-ed over like the 30 of us that posted in a thread I created a while back.
Just buy from some other REPUTABLE online dealer. Also, don't expect any kind of performance increase from an aftermarket cat. The one nissan uses is already 2.5 inches and flows just as good as any on the market.
The ONLY time a "high flow" (which the stock is) "might" be worth it is if you are boosted (in which case you probably would not want any cat). You will not gain hp over the stock one because the stock one is probably the best quality cat you will find. Car makers are under tremendous pressure to use VERY HIGH quality cats due to federal laws.
Old Jan 12, 2005 | 05:23 PM
irish44j's Avatar
retired moderator
so...you have some opinions on the matter, do you?
Old Jan 12, 2005 | 05:39 PM
Zero Deuce SE's Avatar
Originally Posted by mdloops
E55OMG2 - GOT any proof it flows "MUCH" better? Didn't think so. Post a dyno before making claims contradicting 90% of the maxima population
The cat only needs to last 96months/80k miles to meets the federal emissions (specs) laws.
Old Jan 12, 2005 | 07:21 PM
mdloops's Avatar
thanks for the clarification. Everybody knows how I feel about warpspeed. Unfortunately I am not alone. 96 months is much longer than any other standard part warranty from a manufacturer.
Mark
Old Jan 16, 2005 | 01:27 AM
mdemonte's Avatar
Anyone have any information regarding Cattman's catalytic converter. I know he has been working on one. I have checked his website still old same one. I heard he was supposed to update it.
Old Jan 16, 2005 | 10:58 AM
E55AMG2's Avatar
Wat
I do and I can. As anyone knowledgeable about these sorts of things knows, a high flow convertor ONLY works when the exhaust is fully modified.
Wrong again, you just have to talk to him. I had my Y and B pipe redone twice because they werent the correct fit. Also, he was nice enough to replace one of my subframe connectors because it started rusting.
Wrong yet again. The nissan one does NOT flow as well. Also, its not truly 2.5". The flow rate is fine until you really start moving air (Y pipe or headers) and until it melts itself shut from said mods.
You dont have to be boosted. It isnt the best quality. Thats not entirely true....
Old Jan 16, 2005 | 10:59 AM
E55AMG2's Avatar
Wat
Havent heard anything about any updates on his cat....I am interested to see what he will come up with
OT: Also, check the southeast forum. We have a meet coming up
Fbana41
Aug 29, 2016 12:18 PM
pears
Sep 18, 2015 05:25 AM
carid
Sep 9, 2015 05:06 AM
