which optima battery fits 02 max?
Old Jan 14, 2005 | 09:49 AM
keanders21's Avatar
Anyone know which optima battery fits the 02 max?
Old Jan 14, 2005 | 10:02 AM
E55AMG2's Avatar
Wat
Optima D34A or D31A
D34 is a normal size battery
D31 is a competition battery, its huge, and weighs 62lbs.
Old Jan 14, 2005 | 10:12 AM
keanders21's Avatar
thanks I brought a 34/78, but I can't get the positive battery cable terminal to reach to the post. It reaches fine on the negative side.
Old Jan 14, 2005 | 10:15 AM
Digger01's Avatar
I just bought the 34 R with the reversed posts.... I still had to mangle the positive clamp anyway. The people at Optima and Remy suggested this battery.
Old Jan 14, 2005 | 10:21 AM
keanders21's Avatar
how did you mangle the positive clamp?
Old Jan 14, 2005 | 11:30 AM
Digger01's Avatar
Well i needed to straigten it to reach further across the top of battery. I used a sharp hand saw to cut the plastic on each side of the terminal. Then i put a large wrench with pliers..... and carfully placing them the metal parts of the clamp. Then i bent the connection to as to let it reach further across the top of battery. I will improve this soon by purchasing conectors to do it right. Also, the top of the fuse popped out and i never did find it (square fuse in connector) And i have some duct tape holding the red plastic cover on top of the battery. there is another memeber who had the same problem and heere is his comment to correct it
Since i contacted a group member who suggested the following:"I bought lead terminals that have a screw on one end and posts that screw on(not in). Then I put them together and used it as an extension for the battery." (nailz420)
good luck
Ps used a small piece of wood to make up the difference in the height of the batteries to tighten the battery clamp
Old Jan 14, 2005 | 01:03 PM
NYC TAR's Avatar
35-75 is much more easy batter to work with ( fit like a glove with out any mod). The down side that it on have 720 CCA of cranking power, compare to 800CCA 34 battery. Usually the 35/75 is 20- 30 bucks cheaper.
Old Jan 14, 2005 | 03:45 PM
E55AMG2's Avatar
Wat
You can buy a post extension or a terminal extension. They are like 4-6 bucks and take 5 minutes to install. Sears carries them
Old Jan 14, 2005 | 05:05 PM
dadiesel's Avatar
Are there any places with better deals than others?
Old Jan 14, 2005 | 08:43 PM
VQuick's Avatar
Chassis Freak
Batteries.com has free shipping on all their batteries including Optimas and there is a 10% off coupon which I used just last week, I think it's still good. I think the coupon code was "SS10", try that. I got my Red Top 34/78 for $117 shipped.
Old Jan 14, 2005 | 09:50 PM
maximagray's Avatar
i bought the red top the real fitting for the optima batteries for our car is 35/75 and the 34 is just a stronger battery than the 35. The 35 fit perfect but for sure i know the 34 your gonna half to somehow take the lil clips off and extend them
Old Jan 14, 2005 | 10:04 PM
VQuick's Avatar
Chassis Freak
Well my friend and fellow Orger has a '95 and ran the 34/78 with no problems. Maybe the 5th gen battery tray is smaller. BTW, isn't it 25/75 not 35/75?
The Frye
Sep 2, 2021 11:03 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
