power seat problem?
Old Jan 17, 2005 | 10:17 AM
jay929rr's Avatar
power seat problem?
my drivers seat will not move forward or back but will still move up and down or whatever that direction is.
All fuses look good, anything else i can check before bringing it in?
Old Jan 17, 2005 | 12:13 PM
Yaco_Max's Avatar
It could be two things:
1.- A coin. if this is the case you will need a new motor becuase that motor is burned.
2.- The joystick the wires inside it can be loose. It happend to me and is not hard to fixed....
Good luck....
Bringing it in??? TO NISSAN ..... They will charge you a lot of money like always.
Old Jan 18, 2005 | 01:47 PM
beeda's Avatar
How do you fix the joystick problem? Mine goes forward and back just fine, it just won't go up or down on occasion...
Old Jan 18, 2005 | 02:44 PM
Yaco_Max's Avatar
Well, in my case was pretty simple BC my seat didn't move forward and back, so I took it apart and one wire was loose.... BUt someone told me to replace the joystick just in case , from the junkyard $5 (2joysticks)
Old Jan 18, 2005 | 08:58 PM
ticko's Avatar
same here!!
Old Jan 18, 2005 | 09:12 PM
Kevin's Avatar
theres a TSB on this somewhere, check the stickies
Old Jan 18, 2005 | 09:52 PM
Audtatious's Avatar
Bandwagon Lover
Hit the switch with the side of your fist a couple of times. Works for me...
Old Jan 19, 2005 | 07:19 AM
beeda's Avatar
Here's the TSB # - 02-001C (Interior - Driver's Seat Won't Move Forward/Backward).
lol - the only problem is that I'd probably just bust it off...
I'll have to try it tonight, and see if I can get underneath and play with the wires.
Old Jan 19, 2005 | 12:15 PM
Ivanhoe's Avatar
Is the motor for the '01 the same as the '00? If so, I have a '00 power driver seat (probably not the right place for this, but it does save on browsing time)
ivanhoef@gmail.com
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
