fog lights
Old Jan 18, 2005 | 01:59 PM
ticko's Avatar
fog lights
I wanted to change the bulbs of my fog lights, is the only way to get to them is to take off the bumper?
Old Jan 18, 2005 | 02:04 PM
stevay's Avatar
No. read up silly http://www.innerbean.com/housecor/piaa_fogs.html
Old Jan 18, 2005 | 02:06 PM
Daily Driver2k2's Avatar
No, just remove the underguard cover, there held by clips, you'll see when you get under your car. Its more intimidating than it looks. Once you take out two of the clips , the guard comes off then you have access to your fog lights. You need a 10 mm to get off the nuts, then gently push out the fog housing, make sure you have something soft on the ground where they come out , you may break the housing if it hits the ground . Then twist the cap off, and replace your fogs, very simple to do.
There is a write up on it in the stickies.Check it out!
Old Jan 18, 2005 | 03:07 PM
Charliejag's Avatar
Yeah, its easy to get them out from underneath. Does anybody know how to get the bumper off? I want to clean the inside of my headlight housings. If so, is there any airbag wiring I need to be concerned about?
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
