2k low beam not working
Old Jan 20, 2005 | 10:26 AM
MuskokaPat's Avatar
My drivers side low beam has stoped working. I noticed some discoloration to the Sylvania Silverstar bulb when I replaced it. Unfortunately it is not the bulb although it did look blown . Fuses seem fine, but I couldn't find a specific fuse for the low beam only. Fuseable link is also fine. My high beam still works. Please help.
Old Jan 20, 2005 | 11:11 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You tried swapping the bulb to the other side and it worked?
If not, then the bulb has TWO filaments a low and high, so most likely the low is just blown and the high will work still.
If yes, then your low beam ground wire is faulty. There isn't a low beam fuse only, since the high beam and low beam share the same +12V wire.
Old Jan 20, 2005 | 12:18 PM
MuskokaPat's Avatar
I did try swapping bulbs and its not the bulb. Where does the ground wire go from the wiring harness? Would I be able to fix this easily myself or is it very complicated? thanks
Old Jan 20, 2005 | 12:24 PM
IceY2K1's Avatar
Well it could be the H4 plug or it could be in the harness.
You good with a multimeter?
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
delerium75
Aug 19, 2015 11:08 AM
MikesChevelle
Aug 10, 2015 11:21 AM
kenc15
Aug 5, 2015 08:29 AM
