Need help on getting brake booster hose off
Old Jan 29, 2005 | 03:14 PM
Maxima2000SE's Avatar
i just bought seafoam and i already pulled the little clamp thing on the brake booster hose down...but i can't for the life of me get the hose off the thing it goes over. should i spray something on it to loosen it up b/c i cannot get the hose off after pulling for 10 minutes and not moving at all....
Old Jan 29, 2005 | 03:54 PM
twisting and pulling at the same time isnt helping at all...how hard is it to use when it is going through pcv valve??? some1 please help..oh should i be trying to pull it off with the car on or off??
Old Jan 29, 2005 | 04:37 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
make sure the car is warmed up for the seafoam and the heat will make the rubber expand enough to make it easy to get off. make sure you loosened the clamp and pulled it further up the line. then pull and twist and it should come right up. also when i say warm, i drove my car into work before using the seafoam. it wont do much if you let it idle for 5 mins then try it.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
