6speed with STS and Poly Bushings...REVERSE is TOUGH
Ever since i installed the poly bushings for the shifter on my 2k2, it has been really rought getting the shifter into reverse
does anybody else have this problem???
looking for pointers or ideas to resolve this
oh yea,
i had this problem forever... It goes half way in sometimes, and now you just really need to feel it click in. I had this problem before the sts and new bushings, now it makes it a bit worse because the new bushings have less play and it's either in or out. Also, allow the car to warm up, it won't shift as easy cold i noticed. I understand this to be pretty typical, i did make a paranoid thread about this awhile ago.
I had that problem, too. I put some white lithium grease (suggested by DaveB) inside the bushing that sits on the tranny and the same at the base of the shifter. Just a couple of drops so they rotate around the pins a little easier. Also, I slightly back off the nut that holds the bushing at the bottom of the shifter, and used locktite to hold it in place. That puts less pressure on that bushing so it's easier to get over into reverse. All my shifts are nice and smooth...and short now.
knight_yyz
11-01-2015 01:34 PM
KabirUTA13
19
10-17-2015 02:15 AM
